Pls Help!!! What cam For My Set-up?
rockn67gt
juneau alaska
i have a 94gt M/T with 5.0 i just rebuilt. lower end all stock. new (brg's and rings), stock heads. i put on TrickFlow StreetHeat intake with a BBK 65mm TB and this set up is made for the 94/95 5.0 with the adapter. i put in a B303 cam and i dont think this is the right cam. the car will not idle right and it keeps stalling at idle. from what i have been reading in these forms is that this cam dosnt work well with the computer. if this is true, dose anyone know what Cam i should use for my set-up and still work with my computer? thanks guys and gals for your input, i sure could use the help.
the bcam doesn't work well with the computer in stock form. you can tune it to work fine. i would recommend a tune with whatever cam you decide to go with. a dyno shop is the best bet but you can tune it yourself as i kinda doubt there are many mustang performance shops in alaska. :rolleyes:
The best cam for stock heads is the stock cam.
- Jay Allen
Like mentioned above, you'll need to have the car tuned for it to run properly. If I were you I'd put the stock cam back in and retard the timing 4 degrees.
Adam
The Steeda 19 will idle like a stock cam, and will give more power than the stocker.
The only thing is, it doesn't really make power till about 3000 RPM as it is really a supercharger cam, but will work in N/A set-ups.
Whether you keep the B-cam or get another, tune it.
