PLS HLP: Overheating on Freeway
  • Thread starter Thread starter jrnstang
  • Start date Start date Sep 25, 2008
J
jrnstang
44
  • Sep 25, 2008
Guys,
I am stumped at the fact that my car tends to overheat (temp keeps rising) while going 70 on the freeway (Under Load). My car is stock factory with the exception of an Aluminum Rad. My cooling system (Water Pump / Heater Core Bypass/ 180 Degree Therm. / New Upper & Lower Hoses / Stock Plastic Fan w/Working Clutch) has been checked and rechecked. I have also run the car on the freeway without the Thermostat and still overheats (probably not allowing the coolant to cool in the Rad?). I am leaning towards being a clogged Radiator or something clogged in the block, however when I turn the car on and look into the Radiator via where the cap goes, I can see coolant flowing slowly almost dripping thru the core tubes. Also, I do not lose any coolant or get a smell of coolant in the interior or underneath the car.
For example, with a 15 mile stretch (15-20 minutes) of freeway (free flowing) the car (somewhat cool) went from 160 degrees to 260, all this happening while I was going about 70 mph. My temperature is based on an electronic AutoMeter H20 guage I installed in the OEM hole for the stock gauge (Drivers side front on the intake).
Any help or suggestions would be appreciated. Since I have bypassed the heater core (before overheating started), can I still flush the cooling system?
The Radiator is about 6 years old.Sorry,
I also installed a 1993 Cobra Water Pump Pulley (smaller dia.). I do not have underdrive pulleys.
Thanks in advance for any advise.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 25, 2008
  • Sep 25, 2008
Under the front bumper there is supposed to be a plastic air dam. It is mounted under the radiator and spans the width of the radiator. Its purpose is to redirect air from under the front bumper up into the radiator.
The plastic air dam is likely to be a victim of parking lot damage or the previous owner’s efforts “to clean up things”. It is needed to maintain proper airflow to the radiator.
J
jrnstang
44
  • Sep 25, 2008
Thanks for the suggestion, I also checked that and it seems to be in pretty good condition (no cracks/Warps). That is another thing I can pretty much elminate from the problem.
93 LX
3,081
Norwalk, CA.
Sep 25, 2008
  • Sep 25, 2008
bad t-stat?
bhuff30
6,037
35
129
Olathe KS
Sep 25, 2008
  • Sep 25, 2008
You stated a new radiator hoses, but does the new lower hose have a coil inside it to prevent it from colapsing? It is common to suck the hose shut if it does not have a coil inside to keep it open. Obviously, it would tend to suck shut at higher rpms where the water pump is spinning faster. That's probably why you can see water flowing at idle, but then when you get on the highway, it sucks shut.
After getting the car nice and warm, try popping the hood and reving it to 3-4k rpm while watching the lower hose.
J
jrnstang
44
  • Sep 25, 2008
Yeah, I though about that lower rad. hose and replaced it with the one you described, with the coil on the inside.
Thanks.
J
jrnstang
44
  • Sep 29, 2008
Well guys, I had the radiator inspected/cleaned and the shop told me that their was nothing wrong with it. Therfore, I have eliminated the following suspects?
Water Pump
Thermostat
Upper/Lower Radiator Hoses
Temp Sending Unit to Autometer gauge
ECT Switch
Lower air dam infront of Rad.
Clean Radiator
Oli change revealed no coolant
No smell of exhaust in Rad.
Any suggestions?
bhuff30
6,037
35
129
Olathe KS
Sep 29, 2008
  • Sep 29, 2008
How's the ignition and cam timing? You would probably notice a power problem if one of these is significantly off. Excessively retarded ignition timing can certainly cause a cooling problem, as well as cam timing problems.
What kind of rpms are you turning on the highway? My 2.3 had a cooling problem on the highway with a narrow 1 core radiator and 3500-4000rpm on the highway.
If you got an infared temperature gun, you would figure out better what's going on. Then, you would check the temperature of the upper and lower hoses to see if you are cooling well (with fan on), and if your T-stat is really opening up.
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 29, 2008
  • Sep 29, 2008
An engine that only runs hot on the highway under load and runs cool the rest of the time can only be due to one of the following:
Clogged radiator
Lean A/F mixture (clogged injectors, clogged fuel filter)
Retarded ignition timing
If the temp. gauge intermittently spikes high at other times, you could have a sticking thermostat.
Even with the underside air deflector removed, the engine shouldn't overheat on the highway.
J
jrnstang
44
#10
  • Oct 6, 2008
  • #10
Actually, I noticed that the coolant was really not flowing once the thermostat (180 degree) opened and I did a power flush of the water jackets. I think that did the trick. Took her for a test drive (20 minutes) and never got over 200.
I want to thank everyone for their comments and suggestions. I appreciate guys taken time out of their lives to help out a fellow mustanger.
Thanks again,
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
V
Engine Coolant Leaking?
  • vinzo
  • Jan 26, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
Progress Thread severe97's Project Thread!
  • severe97
  • Jan 27, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 1, 2025
severe97
