- Jun 2, 2005
- 584
- 3
- 19
Monday evening I tore the top half of my engine down,Tuesday,I installed everything.I have an '86 H.O in my 88 T-Bird.I haven't broke the tires loose yet,I'm waiting a day or so to see if anything goes wrong.I checked the piston to valve clearance,and it was close,but O.K.The ported heads are worlds better than the E-6 heads I had.My problem is that I want to install my 60mm t-body instead of my Mark VII 58,but when I installed it,the idle jumps to 1200-1300 rpms.I backed off the idle screw,changed the IAC and TPS,and no change.I disconnected the battery,and no change.I re-installed the 58 and the idle is normal.What gives????
