Ported e6's?
gritchy5.0
69
Rock Island IL
So i bought this roller last week and i found a set of ported heads bagged up in the spare tire well. they are e6's? who ports e6's? it looks to be a profesional job everything is very cleanly done, they also have new valves. So would these be worth trying? anybody ever run a set of these? :shrug:
see if you can get one port flow tested to see if they are worth using. Anything over 200cfm I would consider using...........
I'd be hesitant to even waste money on them to get them flow tested, but you never know. I suppose it'd be worth it just out of curiosity.
The other thing is, they would need to have the chambers measured. Chances are if someone wanted any performance out of a set of E6s, they'd want to grind away the part of the chamber that shrouds the intake valve, which would reduce chamber volume quite a bit.
flow testing one port should cost less than $50, for free heads, that's a small investment. If they were done by a "professional", the chambers should have been addressed as well - easy to see and check.
