  • 1994 - 1995 Specific Tech
Post Intake Install Problems
  • Thread starter Thread starter maximos
  • Start date Start date Sep 19, 2007
maximos
188
Columbus, OH
Sep 19, 2007
  • Sep 19, 2007
This past weekend I installed an Edelbrock Performer 5.0 and a Ford Racing 65mm TB and I'm having a couple problems. I believe the timing is off and that is what the cause of the following problems are. First, there isn't as much power, it just seems to hesitate, also it sometimes struggles to stay on and occasionally when I give it full throttle it will make a loud POP sound. Like I said, I think it's the timing, but please correct me if I'm wrong.
Zero_chance
1,244
Maricopa, AZ
Sep 19, 2007
  • Sep 19, 2007
A definite possibility. Are there any vac leaks?
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 19, 2007
  • Sep 19, 2007
Yes, the timing could be off and a vacuum leak is also a distinct possibility. If you check for both, I think you'll find the cure to your problem.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 19, 2007
  • Sep 19, 2007
+1 on the dizzy and v leak
If you've never done an intake swap
You may not know this tid bit of info
You M U S T run the lower bolt torque sequence 3 to 6 times before
you will obtain an even tightness between A L L bolts
also
After a couple of heat cycles ... you W I L L find a few bolts that
have lost their correct tightness due to the gasket compressing a
tiny bit more
Soooooo
After a job like that ... its always a good practice to look
E V E R T H I N G over you have hosed with that pertains
to the project real good after a couple of heat cycles
Grady
maximos
188
Columbus, OH
Sep 22, 2007
  • Sep 22, 2007
I'll take the upper intake off next chance I get and make sure everything is good.
I've recently noticed what appears to smoke coming from my exhaust when I give it some fairly heavy throttle. It doesn't smell like burning oil or coolant. I've never smelled anything like this before, it's kind of sweet smelling. Gaskets?
My CEL is on also. I'll have to take it to be read, but I'd imagine it's something to do with vacuum lines. Maybe I just hooked it up incorrectly?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 22, 2007
  • Sep 22, 2007
Sweet smelling is a telltale sign of coolant. Did you use 4 studs in the corners to guide the intake down? That makes life much easier, since it'll go down straight, and helps keep the intake gaskets from shifting. I'm betting one or both of the gaskets shifted, and you have a leak between the intake and the heads, so you're getting unmetered air, and some coolant into the intake passages. That would cause both issues you're having, if you've verified there's no other external vacuum leaks and the timing is set correctly.
maximos
188
Columbus, OH
Sep 22, 2007
  • Sep 22, 2007
It definitely does not smell like coolant. It's white smoke only when I floor it.
BlownFiveLiter
18
108
Chicagoland
Sep 22, 2007
  • Sep 22, 2007
White smoke = steam: Coolant/water
Black smoke = too rich: Gas
Blue smoke = bad rings or valveseals: Oil
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 22, 2007
  • Sep 22, 2007
Sounds like these things were not present before you did the intake swap
Color of smoke aside ... seems like something is hosed
You are just gonna have to tear into it and have a look see
Good Luck
Grady
mr_woodster
1,314
Riverside, CA
Sep 22, 2007
#10
  • Sep 22, 2007
  • #10
do you have the filter screen "mesh" beneath the PCV valve, on the back side of the lower intake?
mine managed to drop out one time while it was off, it would blow smoke under throttle until it was replaced.
This is obviously not the cause of the CEL or your other issues.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
