Power Tune?
GMYGT
17
Indiana
I have read suggestions in forums here that a "custom" tune will increase the HP in a 2010 GT. I would like to know what a custom tune entails. Are there any possible negative effects, like reliability? Since more power seems to be the name of the game for most, why wouldn't Ford tune them for maximum power?
I read in another source where the author said a S197 Mustang was tuned at every 500 RPM's up to redline to get the most HP. I don't understand how that one would work.
Custom tunes adjust many features in the computer of the car such as advance or retard the timeing so the octane of gas you use will match your tune. Check your local station to see which three octanes they provide then order your tuner. Do your mods first such as cold air and exhaust before you tune and some places you can get tune and cold air packages together. Since these cars are "fly by wire" it will take the lag in the gas pedal out.
Why Ford dont tune to the max, that can go many ways Im sure they dont want to give you a vehicle the burns the tires at every take off for one reason. I dont run my 93 tune just for this fact and I drive a 6r. :D
A Custom Dyno tune is when you take the car to a shop that does such tuning with a computer and custom tune you just order with a tuner or have emailed to you and you load it into your tuner. Hope this helps. :)
Thanks for the reply. It kelps me understand what goes on. The only down side I have found, is that custom tunes may negate the warranty. American Muscle says in the decription of one of their tuners that the tuner keeps your factory tune in case you need to take it in for warranty work. Looks deceiving to me.
Yes It does void warranty and yes it does save your stock tune. If you return it to stock the they can still see that there was some alteration to the computer. It is said that after you return it to stock then disconnect the bat for 15minutes it will be clear. as most things are use at your own risk and take your chances. :)
The only real risk in getting a performance tune is if the tuner is a moron. Most tunes you get with the tuner you purchase are taken from a large data base and maybe slightly tweaked to your specific mods. If you want to be safe with more power then you can just pick up one of the Ford Racing power increase packages.
