Fox Prepping a '91 to start after 5 years sitting?
  • Thread starter Thread starter 331strokerGT
  • Start date Start date Oct 4, 2026
331strokerGT
1,244
North Carolina
Oct 4, 2026
  • Oct 4, 2026
I have not started up my '91 Fox body in about 5 years. It's been sitting in my garage for that time, but I did not correclty prep it for storage i.e. fuel treatment, etc..
I see most procedures start with verifying the condition of the fuel and tank; maybe start with a manual transfer pump to siphon out the fuel and a cheap borescope to inspect? Hope the tank is decent, including the pump and sender?
Or is this just wishful thinking and just drop the tank as it likley will need to be replaced?
DadLife0724
I vote for a new bung hole.
Mar 22, 2024
456
312
73
Cooperstown, PA
Oct 4, 2026
  • Oct 4, 2026
I would say depends on what gas you put in it. I use ethanol free. It stays much better than ethanol gas. You could be looking at a fuel tank full of varnish. Definitely verify before pumping any up to the engine.
AeroCoupe
6,261
4,342
183
Claremore, OK
Oct 4, 2026
  • Oct 4, 2026
You need to drop the tank after you pump it out. It’s not hard to do and this will allow a better inspection. I would replace the rubber line between the fuel pump and fuel pump hanger and the fuel pump sock filter. If it’s the stock fuel pump I would just replace it due to the age.
Reactions: Potomus Pete
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Oct 5, 2026
  • Oct 5, 2026
I'd siphon out the tank and inspect what you get. If you can, put fresh gas in and change the fuel filter. It really all depends on how much moisture got into the fuel tank to turn that fuel to varnish. If you can get a borescope down the filler that would be good otherwise you can siphon and drop tank and see the condition. If it was relatively tight it should actually be in decent shape.
My car sat for 8 years, and then later 4 years with fuel in the tank (definitely E10 the 2nd time), and it looked spotless when I inspected.
Otherwise, change the oil, squirt a little oil into the cylinders and turn engine over by hand a few times.
Reactions: limp and DadLife0724
keel
292
135
53
Seattle, Wa
Oct 5, 2026
  • Oct 5, 2026
Crank the engine over on the starter for about 10-15 seconds to build oil pressure before you fire it off. You can do this by jumping the starter solenoid with an alligator clip or even a screwdriver.
AeroCoupe
6,261
4,342
183
Claremore, OK
Oct 5, 2026
  • Oct 5, 2026
Or pull the distributor and prime it with a cordless drill so you done scar the bearings on a dry crank.
Reactions: gkomo
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,520
2,947
173
Florida
Oct 11, 2026
  • Oct 11, 2026
Maybe just pull the coil wire??
limp
5 Year Member
Oct 4, 2020
5,520
2,947
173
Florida
Oct 11, 2026
  • Oct 11, 2026
I can be pretty anal but this is overdone way too many times...
Smell the gas.. Smells OK, move forward, smells bad, siphon out and put in some fresh gas and a new fuel filter.
Pull the coil wire and crank it over until you read some oil pressure
MAYBE pull the plugs before you crank it over and squirt some oil or lube in each cylinder before cranking
Reinstall plugs, start the bithc. ( spelled incorrectly for the Karens)
Reactions: DadLife0724
keel
292
135
53
Seattle, Wa
Oct 12, 2026
  • Oct 12, 2026
I prefer not to do it this way because the injectors will still fire and it's probably not great for the cylinder walls to have a bunch of fuel coming in while cranking for an extended period. Could also pull the fuel pump relay and then use the key. That's just me being overly careful though.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Oct 12, 2026
#10
  • Oct 12, 2026
  • #10
Foot to floor. TPS signal maxed out. ECU in flood clear mode and the injectors will not fire.
Reactions: Mindseye007
General karthief
Mod Dude
Aug 25, 2016
28,142
10,761
213
polk county florida
Oct 12, 2026
#11
  • Oct 12, 2026
  • #11
Key off, jump the solenoid with a screwdriver, use a mechanical oil pressure gauge.
Oh, make sure it's in neutral
Ask me what happens if you don't check.....
DadLife0724
Mar 22, 2024
456
312
73
Cooperstown, PA
Oct 13, 2026
#12
  • Oct 13, 2026
  • #12
What happens if you don't?
LILCBRA
Mod Dude
Dec 6, 2005
6,658
5,701
194
Corn County USA
Oct 13, 2026
#13
  • Oct 13, 2026
  • #13
Reactions: Mindseye007, General karthief, Blackhawkxx and 1 other person
LILCBRA
Mod Dude
Dec 6, 2005
6,658
5,701
194
Corn County USA
Oct 13, 2026
#14
  • Oct 13, 2026
  • #14
A little late to the party but I'll add to the discussion - clear your lines and rails as well. The fuel in them will be just as bad as the fuel that may have been left in the tank. It will take quite a bit of time to get it cleared out if you only deal with the tank and try to run it from there.
Reactions: limp and General karthief
limp
5 Year Member
Oct 4, 2020
5,520
2,947
173
Florida
Oct 16, 2026
#15
  • Oct 16, 2026
  • #15
Good point, I am thinking carb... Isnt' there a fuse you can pull ?? I see it done on you tube all the time
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
A
Resolved 1989 Mustang bogs down after 3-5 minutes of driving.
  • Alabama
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech May 26, 2025
limp
