  • 1994 - 1995 Specific Tech
Problems resetting keyless entry
  • Thread starter Thread starter blk94snk
  • Start date Start date Jun 13, 2005
blk94snk
  • Jun 13, 2005
Maybe you guys can help..The car is a 94 cobra. I've reset a few keyless entry systems b4 but never ran into this problem. If you're not familiar you short the prongs on the open connector coming from the keyless box. Anyway, the prongs will not short. I've tried everything from a screwdriver to a fuse to copper wire. I'm getting 5 volts to the connector, but no luck with the trip. Can anyone shed some light?
5.0 from 95
738
Emory, TX
Jun 13, 2005
  • Jun 13, 2005
Have you checked that the fuse to the keyless system is not blown? Is the car set up for keyless entry, from the factory? If both of those are good, it should be just as easy as what you are doing.
Paul
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,024
434
113
St. Louis, MO
Jun 13, 2005
  • Jun 13, 2005
stupid question you do have the key on the ON position??? Sorry have to ask.
blk94snk
  • Jun 13, 2005
The key is in the ON position when i'm trying to trip the connector. I haven't checked the fuse physically, since I don't have the owner's manual to know which one it is-but I did check the connector with a volt meter and i'm getting juice. If someone could help with the location of the fuse, I'll check it. Thanks
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,024
434
113
St. Louis, MO
Jun 13, 2005
  • Jun 13, 2005
http://www.ponyperformance.com/tech5.html
there you go... also check there article out for remote programming.
blk94snk
  • Jun 13, 2005
Ok so I've checked the fuse and everything looks good. Any other ideas? The rke module itself is good for a fact. I just took the neg. terminal off to clean posts- before that it was working fine. Thanks again for all the help.
blk94snk
  • Jun 14, 2005
does it sound like an electrical problem?
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jun 14, 2005
  • Jun 14, 2005
If you are asking "how" to reset it, I dont know what you are doing in the fuse box. All you do is cycle the engine on/off a few times in rapid succession until the doors unlock, then push the button.
I just went through this a few weeks ago with the 'scort.
RC
blk94snk
  • Jun 14, 2005
I thought that method only worked with 98 and ups?
94GTLaserRC
11,178
Jun 14, 2005
#10
  • Jun 14, 2005
  • #10
IM not sure, but my Escort is a 97. The Keyless entry remote is the EXACT same (model number and all) The ONLY difference b/t the 2 is that the Mustang keyless remote has a pony on it. Since my Stang has an alarm, I was able to use the stock keyless entry remote as a spare for my Escort DD.
RC
maypo59
194
Central Kentucky
Jun 15, 2005
#11
  • Jun 15, 2005
  • #11
as I remember I ended up using a pair of needle nose pliers I think... here is alink to EXACTLY how I did it on mine when I discovered I had keyless entry, then went on eBay and bought a couple fobs..
http://www.ponyperformance.com/index.html
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Jun 15, 2005
#12
  • Jun 15, 2005
  • #12
I agree with RC.
I was at the local Ford dealer a while back getting a diagnostic done and I asked them if they could also reset my keyless cause it didn't work. The manager hopped in and did exactly what RC described for free.
94GTLaserRC
11,178
Jun 15, 2005
#13
  • Jun 15, 2005
  • #13
Car Nut said:
I agree with RC.
Actually, when I set the old one..the new one stopped working...I went to a DODGE dealer that has a svc mng that came from Ford...he hopped in and did BOTH for me...no charge
Just try that.
RC
Did an auto reset procedure earlier, few questions
  • from6to8
  • Jun 19, 2024
1994 - 1995 Specific Tech Jun 19, 2024
from6to8
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
M
Engine starting issues/ no start
  • Mustang72h
  • May 28, 2024
Fox 5.0 Mustang Tech May 28, 2024
Mustang72h
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
