hotmustang331
Gearbanger 101 said:The standard large capacity return style pumps are powered by a constant and consistent voltage level in order to maintain maximum flow and pressure, under wide open capacity at all times in order to provide a constant and steady fuel supply to the regulator. Their voltage and flow rates remain the same at all times, since excess fuel is managed by re-routing it back into the tank.
Non-return style pumps are variable voltage units and supply fuel based on whatever is read by the electronic fuel pressure sensor and sent by the ECU in order to keep a constant and required supply. Under different loads, fuel demand varies and voltage to the pump will increase and decrease accordingly to demand.
Long story short, the non-return style pumps are built to perform at varying rates, where the return units are not. The constant on and off cycling of a return style pump when trying to fulfill the demands of the non return style system not only shortens its life span, but since the return style pumps are built to perform under wide open, high voltage, high capacity levels, they're less efficient and more inconsistent when under variable voltage conditions. Their pulse width is tougher to tune for than a variable voltage units as a result.
Thanks GB
