My next mod will probably be a bigger throttle body (cant think of what else to do) and I can get a 70mm Professional Products one for $150 new. Does anybody know anything about their stuff?
9150ho said:i have a 70mm tb, and im not that impressed with it, the throttle plate is a poor fit because sometimes it will stick when im trying to press the gas, I have to press harder on the gas pedal than it gives way and my motor revs, its kinda embarrasing.
ratrapp said:i have there typhoon intake.i've had it for a year now and no complaints except it sits rather close to the distributor.i just installed one of there sfi balancers on my car last night and it took some of the vibrations out of my car plus it revs alittle quicker too.i never used there tbs,i put an edelbrock 70mm on mine.i've heard some people complain and some praise it.it will depend on your budget more than anything.
DMAN302 said:I replaced my BBK 70 with a PP 65mm quality is good, and polished items look pretty good. You get what you pay for but you have to be realistic about how much to spend. I recomend it over BBK and have had no issues with it or my intake. As for chasing the threads, the upper should never be torqued over 10ft lbs to the lower, so striping a thread should never be an issue.
AXIStang said:Not stripping, there was casting "flash?" in a few of the upper-to-lower bolt holes they didnt even want to start. No biggie just didnt expect that from a new part.
other than that I think they aren't that bad TB they seem no different than other TB's I have seen.tony91723 said:I have a P.P. 70 MM TB on my LX, I had that same problem with the throttle blade sticking and the idle being kinda rough. All I did was adjust the idle screw some more and it was fixed havent had any problems since.other than that I think they aren't that bad TB they seem no different than other TB's I have seen.
