Proportioning valve
  • Thread starter Thread starter castrol69coupe
  • Start date Start date Sep 24, 2004
castrol69coupe
210
Spring, TX
Sep 24, 2004
  • Sep 24, 2004
Guys, I need to finish my disc brake swap, and its killing me to not
be able to. I need a 78-79 ish Granada proportioning valve. The one
my swap came with wont work, because it is missing pieces.
Help.
Someone on here has to know where I can get one of these things at
a reasonable price.
HELP ME PLEASE.
Thanks.
~castrol
O
Opentracker
20+ Year Stangneter
Feb 4, 2004
516
  • Sep 24, 2004
This is what we use.
www.streetortrack.com has 'em for a good price.
John
P
PCH_Cruiser
69
Palmdale, CA
Sep 24, 2004
  • Sep 24, 2004
If a prop valve like that is used, is the distribution block still needed? Does this valve contain a check valve if there is a loss of pressure in the front or rear brake lines?
chepsk8
2,203
Easton, PA
Sep 24, 2004
  • Sep 24, 2004
Check at the junkyards. I'm also pretty sure many different Ford vehicles used the same prop valve. Also look at Mavericks, and other similare sized FOMOCO's.
G
gt/cs
105
SW California
Sep 24, 2004
  • Sep 24, 2004
I don't have that exact proportioning valve, but the design looks to be simmilar to mine. The line from the larger resovoir on my MC goes to a distribution block which splits it out into lines for the driver and passenger side front brakes. The line from the smaller resovoir goes to the proportioning valve, to a pressure gague, then to the line to the rear drums.
No idea about the check valve.
Hack
1,945
Minneapolis
Sep 24, 2004
  • Sep 24, 2004
I would second Opentracker's recommendation. When I did the Granada swap, I used a Granada proportioning valve. Well, it's close, but at the limit my back tires lock first. Not good.
The adjustable valve will always work, no matter what future brake mods you decide to do, or if you put in a bigger engine, put the battery in the back... any weight distribution changes the brakes can be optimized once again. It's a pretty useful thing to have, IMO.
castrol69coupe
210
Spring, TX
Sep 26, 2004
  • Sep 26, 2004
Thanks guys. I just need to get this car back on the road ASAP. Its killing me to have it sitting in the garage like it is. Weather is getting nicer, and this thing needs to be OUT. Thanks for the advice.
~castrol
Snail50
787
Miami
Sep 26, 2004
  • Sep 26, 2004
John
That's the one I have too. Mine came with the Baer kit, is marked "Baer" but it's a Wilwood valve.
I bypassed my distribution block when I did the rear line; now the rear brake line goes from the MC, through the prop valve (mounted on the firewall), and to the rear brakes.
You'll get a brake fault in the instrument panel, but that can be eliminated by unplugging the sensor on top of the dist block. I left the ports on the dist block open, with the lines for the front brakes in place, and I've had no leaks or problems.
Snail50
787
Miami
Sep 26, 2004
  • Sep 26, 2004
send 69StreetGrande (I think that's his name) a PM; he did a very nice custom job on his brake setup. You could probably find pics of it on his website:
www.trinitysmustangs.com
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
P
Rear disk brake caliper parking brake adjustment
  • parrotguy
  • Oct 23, 2025
1974 - 1978 Mustang II Talk & Tech Oct 24, 2025
2Blue2
Fox Is the fox market for average cars crashing in your area?
  • rednotch
  • Oct 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
FastDriver
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
