Pull engine & trans together or just engine?
  • Thread starter Thread starter ShawnR
  • Start date Start date Jul 14, 2025
Engine swap - pull by itself or together with trans (manual)
  • Pull engine and trans together
    Votes: 1 50.0%
  • Pull engine and leave trans in car
    Votes: 1 50.0%
  • Total voters
ShawnR
Central OH, USA
Jul 14, 2025
  • Jul 14, 2025
I'm getting ready to pull the 4.6 out of my kids 03 for a long block swap. TR3650 trans.
I'm planning on pulling the trans and engine together unless there are recommendations to pull the engine by itself. I'm a little worried about trying to line up the input shaft from a fixed transmission into the clutch when putting things back together. Wiggling the engine around just doesn't sound like an easy project. I've pulled lots of engines over the years, but very few with manual transmissions.
Thoughts?
squeak93
2,325
401
164
Joplin, Missouri
Jul 19, 2025
  • Jul 19, 2025
Pull both together. I find it easiest to have car (all 4 corners) up on jack stands as tall as you can get it, unbolt/loosen/disconnect everything. Then when the cherry picker is hooked up and ready to yank the engine, drop the front end back down on the tire/ground to help clear the front Rad support. This helps not hit the limits of the cherry picker height and then have to either scratch the hell out of the core support or wrestle the engine over it.
Auto's or manuals come out just as easily as each other. No real diff other then weight so make sure your chain and bolt points are up to the task.
Reactions: ShawnR
ShawnR
Central OH, USA
May 2, 2026
  • May 2, 2026
Bump because I added a poll. Currently planning to pull them together, but wanted one last try for opinions.
Admin Dude
Jan 4, 1985
43,387
21,589
234
Box behind Walmart
May 2, 2026
  • May 2, 2026
Great. Now you'll have some leverage.
RaggedGT
Mod Dude
Jul 20, 2014
4,754
3,208
203
Taylorsville ky
May 2, 2026
  • May 2, 2026
I’m mostly by myself in the garage. So if I don’t have to try and wrestle an engine and trans out or in together. I usually don’t
Lol
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
K
Intense Shaking problem
  • KP_NewEdge
  • Jun 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 11, 2025
gkomo
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
