  • SN95 4.6L Mustang Tech
Pulleys: Steeda, March, Slp
  • Thread starter Thread starter FOXCOUPE
  • Start date Start date Sep 1, 2006
F
FOXCOUPE
399
vancouver
Sep 1, 2006
  • Sep 1, 2006
All 3 are non piggy back and have a SFI aproved dampner but are they different in size? Is one brands crank, alt. or wp. pulley smaller or bigger then the other? If this is the case then maybe this is why some people claim to have made gains and others have not.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Sep 1, 2006
  • Sep 1, 2006
cant go wrong with steeda
lvmustanggt
721
Las Vegas
Sep 2, 2006
  • Sep 2, 2006
I have steeda and it's good. FRI UDP don't worth *****. I may got 2rwhp out of it
StangPro
441
Roseville, MI
Sep 2, 2006
  • Sep 2, 2006
The dampers are all different materials and durometers too, so they have different dampening characteristics for the harmonics. What this means to you is each one makes your engine wear differently.
Using anything but Steeda or SHM can lead to 70k rebuilds (worst case, but I've seen it).
fluffyrunnells
new hampshire
Sep 2, 2006
  • Sep 2, 2006
steeda +1
F
FOXCOUPE
399
vancouver
Sep 3, 2006
  • Sep 3, 2006
For those of u with steeda pulley's, did u actually feel any improvment or is it more of a "dyno" mod?
T
Torinalth
952
Clayton NC
Sep 3, 2006
  • Sep 3, 2006
maybe i am wrong here... but if i am not mistaken i believe SLP has steeda make theirs.... either way, i'd go steeda.
Torinalth
the98stang
2,408
Clovis, CA
Sep 3, 2006
  • Sep 3, 2006
You should get 7-9 WHP. Looks like you got raped . Anyway, every little bit helps...
StangPro
441
Roseville, MI
Sep 3, 2006
  • Sep 3, 2006
Torinalth
We stock both, and that's how it looks to me.
I think SLP realized the Steedas are excellent parts.
CobraRed_96_GT
1,421
UCSD/La Jolla
Sep 3, 2006
#10
  • Sep 3, 2006
  • #10
I got steeda's, you notice it in the throttle response but nothing to shat urself over
StangPro
441
Roseville, MI
Sep 3, 2006
#11
  • Sep 3, 2006
  • #11
lol...well put.
hotmustang331
2,967
Bastrop,TX
Sep 3, 2006
#12
  • Sep 3, 2006
  • #12
Stock dampener is better than any of the above mentioned...even steedas.
Get the March piggy back pulleys...they are only $130ish and you get to keep your stock ballancer. I have them and ZERO problems, they even went on the crank without issue. I love em . And use RTV sealant in the grooved key passage as directed or it may leak engine oil.
StangPro
441
Roseville, MI
Sep 4, 2006
#13
  • Sep 4, 2006
  • #13
That's actually horrible completely incorrect advice.
In stock form this would be true. When you piggyback the crank pulleys though, you increase the dampers weight significantly and move the damper farther forward. This results in greater wear on the engine.
OV10stang
48
Pembroke, NH
Sep 4, 2006
#14
  • Sep 4, 2006
  • #14
You might get a couple hp higher up, like at 6k or so. Like someone else said, every little bit helps. I mainly did it because I'm running 4.10's and always turning more rpms than normal. When on the highway, I'm turning about 2800 rpms at 75 mph.
hotmustang331
2,967
Bastrop,TX
Sep 4, 2006
#15
  • Sep 4, 2006
  • #15
You apparently never installed piggy back styles before. The only possable increased wear would be on the front main bearing....and the force of say a supercharger (tight belt) would HEAVILY HEAVILY HEAVILY wear it more than a few more #s on the crank.
Steedas and the others dampener is smaller, and doesnt remove the vibrations as effectivly as the stock one....ill take a SUPER slightly more worn front bearing than more vibration going through my rotating assylembly @ 6200RPMs. There have been many engine failures reported (I did some looking into this crap before I decided which kit to get...PB or new ballancer) on engines with aftermarket UD pulley/crank dampeners.
Steedas will not reduce harmonics as well as the stock one, but its reported to be the best on the aftermarket...and isnt much worse than stock.
Dont ask where I accumulated this info from as its been a while...but thats why I didnt put an aftermarket dampener on my car that sees more RPM than the adverage 2V. If you MUST get an aftermarket dampner, get steedas.
EDIT: have you seen the GT-500 motor? It has a setup simular to the piggy back style I have...huge dampener/pulley pushed out for the drive accessoris, and a pulley behind it turning the S/C. Its the same thing as what I did...and I doubt Ford would do that if it had any ill effect.
TangerineGT96
134
arkansas
Sep 5, 2006
#16
  • Sep 5, 2006
  • #16
STEEDA!!!
T
Todd00GT1
38
New Cumberland, PA
Sep 5, 2006
#17
  • Sep 5, 2006
  • #17
I have Steeda. I always heard Steeda has the best when I was doing my pulley shopping.
stng
182
#18
  • Sep 5, 2006
  • #18
+1 for what mustang331 says... I also did quite a bit of research before installing mine. I too had heard all the horror stories about the piggyback style, but after researching it they turned out to be more of an "Urban Legend" than anything. I have been running the March Piggyback style for years now with absolutely Zero problems.
sgarlic
3,085
Sep 5, 2006
#19
  • Sep 5, 2006
  • #19
I did the Steeda pullies after years of telling others not to. Anyway, I'm glad I did.. my gas mileage has improved and that new crank pulley looks 500 times better than the old brown rust colored stock one did.
I used my air compressor quite a bit. Easy installation if you follow directions well, and if you rent the pulley removal tool from Autozone.
P
Pennywise2
Banned
May 16, 2006
1,379
#20
  • Sep 6, 2006
  • #20
I have had Steeda Underdrive pulleys on my mustang for the
past four years and I have had no problems with them.
I also can feel more throttle responce!
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
M
  • mnky99
  • Sep 5, 2025
mnky99
M
J
  • JRC99
  • Apr 19, 2025
JRC99
J
