Pushrod Question
  • Thread starter Thread starter BKM48198
  • Start date Start date Mar 14, 2014
BKM48198
377
27
49
Ypsilanti, Michigan
Mar 14, 2014
  • Mar 14, 2014
Changing heads from stock 5.0 HO E7's to GT40's, which pushrods should be used? I just want to make sure I have the right ones when I go to change the heads.
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Mar 15, 2014
  • Mar 15, 2014
Depends on the setup, but I needed .060 longer than stock and a shim kit.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 15, 2014
  • Mar 15, 2014
The only way to know is by using a pushrod length checker- comp cams makes one. Your pushrod length is going to depend on a number of factors such as
deck height
head gasket thickness
head thickness
RR ratio
RR type- pedestal or stud
spring height
There are a number of tutorials on the web on how to check. You do not want to guess or you can end up with improper valvetrain geometry that leads to all sorts of problems.
BKM48198
377
27
49
Ypsilanti, Michigan
Mar 15, 2014
  • Mar 15, 2014
deck height
head thickness
RR ratio
spring height
BKM48198
377
27
49
Ypsilanti, Michigan
Mar 15, 2014
  • Mar 15, 2014
If I use stock heads that have not been touched on a stock block with no changes, everything the way it came from Ford will there still be changes? I can understand if the heads were milled but if I use rods from the same motor the heads were on the only real difference should be size of the gasket. Or am I missing something?
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Mar 15, 2014
  • Mar 15, 2014
Sometimes you can get away with it. I was able to. However, like everyone else stated, you will not know for sure until you check.
Joe
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • Mindseye007
  • Aug 16, 2026
Mindseye007
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
