  • SN95 4.6L Mustang Tech
putting a stall and long tubes on 2000
  • Thread starter Thread starter dastang2
  • Start date Start date Oct 12, 2008
dastang2
2,020
tx
Oct 12, 2008
  • Oct 12, 2008
i just pulled the trans yesterday. i am putting a 3600 stall and long tubes with o/r h on the car in a few weeks. i the trans has a b&m shiftkit in it and not sure what else has been done. i have stock 3.27's on a full weight convertable. what can i expect of the performance i will gain. i have o/r h and 1 chambers on it now with a j mod on the trans.
J
justinschmidt1
349
  • Oct 12, 2008
probably .5 with traction...maybe more
scupking
1,186
Enfield, CT
Oct 13, 2008
  • Oct 13, 2008
I would highly suggest putting in some 3.73 or 4.10 gears.
dastang2
2,020
tx
Oct 13, 2008
  • Oct 13, 2008
410s are the plan
04YELLOWGT
1,135
Indiana
Oct 13, 2008
  • Oct 13, 2008
I would def. upgrade the tranny cooler.
R
RoadconeTuning
458
Upstate, SC
Oct 13, 2008
  • Oct 13, 2008
ditch the shift kit and do a j-mod.... also with a stall like that you probably dont need the 4.10... id go 3.73 unless you just want to never be able to trap over 105ish... with the 4.10 in my 04 with a TR-3650 5800rpm is 108mph in 4th gear....
F
FastMustangGT
53
Massachusetts
Oct 13, 2008
  • Oct 13, 2008
have you ever had your car on a dyno?. You want your stall speed just before peak torque. 3600Rpm stall sounds pretty good. I have a 4000stall with comp 270's and a single disc lock up coverter.
dastang2
2,020
tx
Oct 13, 2008
  • Oct 13, 2008
what is wrong with the shift kit. i did the j mod on my trans now and like it. but my trans is going on his car and i am getting his along with the stall. also i have not been on a dyno. on a b&m shift kit does it keep the stock seperator plates or no
F
FastMustangGT
53
Massachusetts
Oct 15, 2008
  • Oct 15, 2008
I didn't know BnM makes a shift kit for these cars.. must be new... Bc-automotive make some awesome valve bodies,like the j mod but on steroids.
dastang2
2,020
tx
Oct 15, 2008
#10
  • Oct 15, 2008
  • #10
if i was to put a 99 cobra motor in this, would this stall still be good to use or would i need a lower stall speed what about ported heads and a cam swap with aftermarket intake.
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 15, 2008
#11
  • Oct 15, 2008
  • #11
Anytime your peak torque goes up in rpm you want a higher stall. A 3600 would be fine for a 99 cobra or a ported set-up, and would be quite substantial for a bolt-on GT, but not overboard at all.
Stark77
501
Tallahassee, FL
Oct 16, 2008
#12
  • Oct 16, 2008
  • #12
I need a stall - for those of you that have them, how much was labor/install?
J
justinschmidt1
349
#13
  • Oct 16, 2008
  • #13
Ive been quoted 500
Stark77
501
Tallahassee, FL
Oct 16, 2008
#14
  • Oct 16, 2008
  • #14
Hmmm - I think that a set of stage II cams + springs + install will remain at the top of my priority list. The stall would really kick ass but only from a dead stop.
dastang2
2,020
tx
Oct 16, 2008
#15
  • Oct 16, 2008
  • #15
i dod all my own work, it's what i do. i also do sidework if any of you are in my area. houston tx
d98gt
4,505
59
204
SE Texas
Oct 16, 2008
#16
  • Oct 16, 2008
  • #16
Since my little 98 is torn all the way down, I really don't think installing a t/c would be a hard task. I have the block out of my car and I can't see me installing it without installing longtubes since I am at this point
I am also in the Houston "area" and do my own work and have helped a few people with misc installs
dastang2
2,020
tx
Oct 17, 2008
#17
  • Oct 17, 2008
  • #17
i am thinking about getting the cobra motor and dropping it in.what gears should i get for a blown 4 valve with this stall
O
Help
  • OnisimusD
  • Oct 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 14, 2025
OnisimusD
O
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
