PWM Fan controller - Need help/clarity on a purchase
stussy2870
71
35
28
45
Butler
Guys, I'm looking to get a PWM Fan controller for the contour fans currently installed. The PO installed these and the wiring is a mess. Im cleaning it all up and what to get a standalone fan controller.
Seems like Autocoolguy's controllers are hard to beat but was hoping for a cheaper option.. I read somewhere that the Contour fans spike at nearly 120A!! Knowing that its damn near impossible to find a controller for under 250.00..
Anyone have any suggestions - would like to buy what i need asap..
  • Sponsors(?)
Steel1
Mustang Master
Aug 18, 2017
1,067
468
113
50
Connecticut
If you're just looking for a decent variable speed fan controller I've had good luck with the Flexalite VSC33054 with
my dual Interpid fans. I think Dakota makes a good one as well and there's some mystery guy that no one can seem to contact who
supposedly makes a quality controller.
Now if you're looking for a PWM controller to work with a Megasquirt or similar ecu, I haven't crossed that bridge yet.
CarMichael Angelo
clearly, I’ve got something going on in that hole
SN Certified Technician
14,159
234
62
Birmingham, al
m.imdb.com
If you have a mega squirt, all you need is a solid state relay, use the right output, and find somebody who can program a pwm duty cycle on that output.
I have that setup. All it took was a 40.00 relay, and Steve.
Blown88GT
2,078
482
134
Palm Beach Gardens, FL
I assume "spiking" is referring to starting current.
I don't know where you heard that, but it's wrong.
The Lincoln Mark VIII fan starting current is 105A.
The dual Contour fans are far less, no more than 60A.
The DCC FK-45 will control any of these. It's $150.
Blown88GT
2,078
482
134
stussy2870
71
35
28
45
Butler
Wow.. Thats what i needed to hear.. Thanks so much. I was leaning that way. Is the Derale really a POS? looks nice.. but man that thing gets sh1t for reviews..
Thanks for all the replys!!
bwest
Can confirm - Contour's use 2 different relay circuits for hi/low. And they pull an insane amount of air. I've also owned 2 SVT contours.
The fans work wonders on a retrofit too. When controlled correctly. A 2 stage (hi/lo) controller would be pretty adequate - It was a rare day for them to switch onto high unless in stop/go traffic + A/C running on a hot day. Those engine compartments were also packed super tight - much tighter than any v8 mustang.
I ran them in a Supra I had years ago and used a PWM controller by Spal (I don't know if it's still in production). Once I got it figured out/setup correctly, i had 1 fan acting as a primary (50-90%) and then when it hit the hot threshold, both fans would kick on at 100%. This was rare. The Supra had an 85a alternator and without a PWM controller, the contour fans were too much (on/off) with the lights running.
TL;DR - they are fantastic fans that draw some serious power. Set up right, they will work as good/better than the stock 2spd fan on the SN95. Get a PWM controller that triggers from an inblock sensor. Otherwise you'll be redoing it again in the future.
Ragtop50
27
11
I have a Flex-a-lite 31165 and have been very happy with it. Great features and PWM functionality.
You can even connect a switch for manual override.
Blown88GT
2,078
482
134
The Derale is the DCC design. His patent number is printed on it.
Better to deal with him directly but you have to be patient. It's a 1-man company & he gets very busy in the summer.
Full disclosure: I am DCC customer #1. If it had a S/N, it would be #2.
BTW, motors have a starting current 3-5 times running current. The high starting current is one way that kills the relay contacts. The Bosch 70A relay is rated for motor loads. The 70A rating is the running current rating. It will start the 105A Mark VIII fan. Also, when the fan turns off, the collapsing magnetic field of the motor creates a large reverse voltage spike which will arc across the relay contacts, so a freewheeling diode is recommended to suppress the spike. Ford uses one on the A/C compressor clutch.
Admin Dude
Jan 4, 1985
28,926
10,904
224
Box behind Walmart
www.stangnet.com
This truly messed me up for a minute. The controller you are looking for is not Pulse Width Modulated or a "PWM Controller". PWM suggests a 3-phase, brushless motor (cool idea now that I'm thinking about it). Having said that, there are controllers that use a PWM modulator as input to dictate voltage to a brushed motor but that is in the place of a variable resistor that would likely cook under load with decent current.
I realize it wasn't the point of your post but wanted to clarify that you can't just send a PWM signal to a set of Contour (or otherwise) cooling fans. Well technically, you could but it would also require an Electronic Speed Control (ESC).
Blown88GT
2,078
482
134
I think you are confused. The unit described in the patent is running my dual Contour fans; it used to run my Mark VIII fan.
Read the patent for a Pulse Width Modulator
Admin Dude
Jan 4, 1985
28,926
10,904
224
Box behind Walmart
www.stangnet.com
The Link Above said:
The present invention encompasses a high efficiency pulse width modulator comprising: a variable duty cycle oscillator for receiving an input signal and providing a low level switching signal
Not confused. The one you linked used a PWM signal generator as a signal input like the ones I described.
Voltage on a 3-phase PWM controlled fan would be constant. Your controller varies the voltage to the fan.
Admin Dude
Jan 4, 1985
28,926
10,904
224
Box behind Walmart
www.stangnet.com
For the sake of comparison:
Pictured above is a Pulse Width Modulator (PWM). It has a power and ground and two contacts that feed a conditioned signal to a module within a Pulse Width Modulated Fan that dictates fan frequency through a digital pulse.
Our cooling fans are the regular style. At 14 volts you get a certain speed and can vary that speed by changing the voltage.
These new-fangled controllers do something a little different. They convert the temperature sensor readings to a digital signal through a PWM. The controller receives it and uses it as the input to vary the voltage at the fan.
I stayed at a Holiday Inn Express last night. :shrug:
A comparison pinout between 3-pin and 4-pin PWM:
I don't possess a contour fan to check but my DCController is often used to run Taurus fans is for the type on the left (brushed style motor).
stasha
15
KY
OK, I've read this thread every day, and after about 30 seconds, my mind goes to blah blah blah.
Might as well get something out of it, so QUESTIONS:
1. What the heck is PWM -- I can read the words, but WHY would anyone want a PWM?
2. Is PWM what gives a "slow start" to a fan?
3. How do you know if you have a brushless fan motor?
4. When would I want PWM?
5. How do I know if I have a PWM?
6. Is the Dakota Digital PAC-2700 fan controller a PWM?
Thanks.
Blown88GT
2,078
482
134
Thanks.
It doesn't vary the voltage, it varies the duty cycle of the voltage, i.e. square wave, 0-12V
1. PWM = Pulse Width Modulation as in the sentence above. Why? Variable speed control.
2. Not necessarily, but is usually part of the design of a PWM controller. It is referred to as a "soft start".
3. Google the part number.
There are 4 main types of DC motors:
  • Permanent Magnet DC Motors. The permanent magnet motor uses a permanent magnet to create field flux. ...
  • Series DC Motors. In a series DC motor, the field is wound with a few turns of a large wire carrying the full armature current. ...
  • Shunt DC Motors. ...
  • Compound DC Motors.
4. When you want to vary the speed according to temperature.
5. Don't know what you know or don't know.
6. If it's variable speed, it's PWM. Variable as in ~10 rpm to max rpm & anywhere in between.
BTW#1, this is not an online class in electrical engineering even if I am qualified to teach it, which I am (LOL).
Google "PWM dc electric motor", then you can teach the class.
1st hit on Google:
BTW#2 Electric cars use AC motors. The battery voltage must be converted from DC to AC. Speed control is not PWM.
The two primary ways to control the speed of a single-phase AC motor is to either change the frequency of the line voltage the motor sees or by changing the voltage seen by the motor, thereby changing the rotational speed of the motor.
Electric cars & all industrial equipment use 3-phase electric motors. Lesson #2, some other time.
BTW#3 Your alternator is a poly-phase (more than 3) generator. A motor can be a generator & a generator an become a motor. Electricity can create magnetism & conversely, magnetism can create electricity. High school physics.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,437
2,869
234
74
Dublin GA
lowendmac.com
Thanks.
Pulse Width Modulation explanation
Starting a motor at 3 volts and then gradually increasing it to 12 volts draws much less current that a sudden application of 12 volts to the motor - hence the term soft start. The ability to run the motor at a variable speed makes it easier to keep engine coolant temperature in the desired range. There will be a minimum of coolant peaks and valleys, more of a constant coolant temperature.
stasha
15
KY
Wow. Thanks to both replies.
I will have to read this again tomorrow.
I catch myself going "blah blah blah", meaning my brain must be shutting down.
Guess the square wave and duty cycle, and changing who sees the freq of the voltage -- etc, is hard to visualize what it means.
I'll try that google source.
(Took several physics courses, but back in the late 60s -- before they invented gravity.
General karthief
Mod Dude
Aug 25, 2016
17,302
5,591
193
polk county florida
Wait, but you show your age as 39, or were you born in 39?
Thread starter Similar threads Forum Replies Date
302RollinHard SPAL PWM fan controller with a Taurus fan FYI....... Fox 5.0 Mustang Tech 4
billfisher 3v VCT pwm controller SN95 4.6L Mustang Tech 9
SuperBobby615 No power to cabin air dial or blower or resistor - 2005 GT 2005 - 2009 Specific Tech 0
Nightstang00 Fox 97-98 mark viii Fan 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
W 1997 Mustang GT AC / Radiator fan acting up 1996 - 2004 SN95 Mustang -General/Talk- 0
A Fox Fan suggestions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
8 Electric fan problem Fox 5.0 Mustang Tech 2
E What electric fan are you guys running? Having trouble locating a GENUINE MOTORCRAFT! 1996 - 2004 SN95 Mustang -General/Talk- 0
B 1994 mustang cooling fan wiring? PLEASE HELP!! 1994 - 1995 Specific Tech 0
Greyfur Cooling fan woes SN95 V6 Mustang Tech 3
B 95 Cobra cooling fan 1994 - 1995 Specific Tech 4
4 Fan went through my new radiator. 1965 - 1973 Classic Mustangs -General/Talk- 2
R Radiator Cooling Fan is running 1996 - 2004 SN95 Mustang -General/Talk- 0
B 95 mustang cooling fan voltage 1994 - 1995 Specific Tech 1
foxbodybill89 Electrical E-fan indicator lights Fox 5.0 Mustang Tech 5
vristang Stock IRCM with Taurus fan 2.3L (N/A & Turbo) Tech 2
9 Air Condition Idle up with 2-speed fan (MSPNP Gen 2 V1.2) Digital Self-tuning Forum 8
G Electrical How to wire a small light to show fan status? Fox 5.0 Mustang Tech 6
maisonmays22 Contour fan controller 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
D 180 thermostat fan settings SN95 4.6L Mustang Tech 0
9 95 cobra 5.0 fan problems 1994 - 1995 Specific Tech 3
James V Electrical Contour fans to a toggle switch, what do I need? Fox 5.0 Mustang Tech 7
N Electrical Can you use the 4cyl electric fan controller in a 5.0 swap? Fox 5.0 Mustang Tech 4
T Fan not turning on 1983 3.8 Fox 5.0 Mustang Tech 0
K Electrical Contour Fan Install with OEM controller Fox 5.0 Mustang Tech 16
9 97 GT Cooling Fan Not Working SN95 4.6L Mustang Tech 2
M 1967 s-code fan problem 1965 - 1973 Classic Mustangs -General/Talk- 2
Tavis 89 2.3L radiator fan possibly not working 2.3L (N/A & Turbo) Tech 8
S Rear Axle and Stock Fan/Shroud help w/ 351w 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
P cooling fan problems SN95 4.6L Mustang Tech 1
V 1994 radiator fan fuse question 1994 - 1995 Specific Tech 3
S Thermal clutch fan recommendations for 1966 Mustang w/ 289 1965 - 1973 Classic Mustangs -General/Talk- 1
M Ford Contour/Mercury Cougar Dual Fans Other Auto Tech 1
T Need good/affordable cooling fan for Mach 1 that does not vibrate too much 1996 - 2004 SN95 Mustang -General/Talk- 3
S 97 gt frustrating fan issue SN95 4.6L Mustang Tech 4
S 02 Gt PCM Flash, Fans won’t stop running 1996 - 2004 SN95 Mustang -General/Talk- 7
F Electric fan 1965 - 1973 Classic Mustangs -General/Talk- 2
H recently installed alluminum radiator and electric fan on 89 5.0 overheating 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
moneypit94 fan wiring questions 1994 - 1995 Specific Tech 1
Blown88GT SOLD Electric Fan Motor Engine and Power Adder 0
Blown88GT SOLD Small Auxiliary Electric Fan Engine and Power Adder 0
Blown88GT SOLD Fan Clutch Engine and Power Adder 2
Blown88GT SOLD Lincoln Mark VIII Fan with Overflow Engine and Power Adder 4
irishgt1 Lets talk electric fans 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
85Punisher Ford Contour fan motor plate? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
N Electrical 94 Mustang Wiring to fuel pump and cooling fan 1994 - 1995 Specific Tech 0
J Engine Fan SN95 4.6L Mustang Tech 5
L SVE DUAL FANS 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 33
C Radiator Fan shuts off even if AC is on. SN95 4.6L Mustang Tech 2
D Electrical High Speed Radiator Fan not coming on with AC on 1994 - 1995 Specific Tech 5
