- Mar 23, 2004
- 9
- 0
- 0
I have the chance to buy a 429 out of a 68 t-bird and was wondering if I could run it with a C4 tranny or had to get a C6. Also, what gears for the rearend should I run. I am not planning to mod this motor much so pretty much stock power. And will I have to get a 9" rear to handle the power or will a 8" be sufficient. Not looking to build a real racer but will take it to the track once in a while. Mainly just to drive around a little and take it to the strip occasionally. Also, any other tips that will be helpful in making the swap would be appreciated. Thanks.
You will need the C6 from the 429 as hungrymonkey said. You will also need to be on the lookout for a 9" rear too, the 8 may last a little while, but eventually the 429 will eat it. You will also need to beef up the front end to handle the extra weight. A brake upgrade will alos be in order, you DO want it to stop , don't you?
