Many remove the quad shocks and there are tons of posts about people ditching them for wider wheels, flipping them around, etc. I'm trying to flip mine around for the same reason - larger tires/wheels. My problem is that I can't get the bolt out! I've gotten the rear-most nut off, but I can't get the bolt out of the part by the wheel. I've sprayed it w/ WD-40 multiple times, tried a breaker bar over a 15mm wrench (the wrench doesn't fit perfectly, but it's the only size that fits. I've also put the impact on it pushing 120psi. Not only that, but I got the torch out and heated it up and then used the impact at 120psi and it still won't break loose!
Not real sure what to do at this point. How did you guys get yours off?
