Quadrant probs. PLZ HELP ASAP
MoparorNocaR
12
Hey guys...
so i was drivin my 87 stang round town wen i went to go downshift and my clutch pedal clicked all the way to the floor... almost like a ratchet noise. needless to say i drove home without a clutch.
Any idea wht it is. i started to disassemble my brake support and im running into problems there. if it matters i just replaced my clutch cable 2 weeks ago due to it snapping. I took apart the steering wheel supports and shrouding. Also i took off the 4 nutes to the booster. and my seat is out. but im having trouble with getting the brake pedal supprt out. how many nuts/bolts are there? where could i locate them. since i have to take this fandangled thing out i mite as well go with a billet one i plan on pickin up at ben pillas or sumplace.(NJ) I have never taken a quadrant out and ive been under the dash for about 4 hours tryin to figure this out. i need this to be completed by 5 pm tommorw for work. all help would be appreciated. and i will be constantly monitoring this thread.
please keep in mind im 17 y.o.... so plz excuse my lack of knowledge. ive been searching the net for removal of this thing but cant find help anywhere.
Thnkyou for your help in advance.
your quadrant did the same thing ? as in, it slipped all the way to the floor? should i just pull the cotter pin and slide it off ? i see another part on the quadrant as well. wht is that, and wht am i aiming to replace ?
You should be able to pull the pin and then just pull the quadrant off. Might have to pry it or shave the side down with a dremel tool as it is a tight squeeze getting it out. Did you check to see if the cable had just popped off the quadrant? Being you just put in a new cable, you may not have got it in there just right. You should not have to take off anything to replace a quadrant though. Atleast I never have. Good luck.
yea, the cable is on their good. matter of fact, im waitin for one of my friends to come over so he can help me take the damned cable off... so you guys just think the quadrant is bad ? id like sum type of diagnosis... thnks
Yes the only thing you will be putting on there is the Aluminum Qaudrant.
I bought the UPR with the firewall adjuster and the adjustable cable.
Was very easy to install and love the feel of it.
I pulled this from one of the links above
Remove drivers seat (not mandatory, but will save you a lot of pain and hassle),
Pull up on clutch pedal.
Jack car up and support securely with jack stands.
Pull the clutch cable housing cover off of the tranny. One small bolt and the cover slides out.
Unhook the cable from the clutch fork. Use a pry bar, or even a foot to depress the fork if necessary.
Crawl on your back under the dash.
Above the gas pedal, you will see two white plastic quadrants that hook onto two shafts. Use a flash light if necessary, these can be difficult to spot for a first-timer. (picture 1)
Remove cotter pins, two of them. Use your finger and push on the pointy side (take the pain!!) or try your luck with some long needle nose pliers or a screwdriver. Patience, this is can be difficult to do the first time, and you can loose those two cotter pins if you not careful. (picture 2)
It is near impossible to see, but the plastic quadrants are held on by a spring under each one. I like to use an OEM tire iron, and pry the quadrant out far enough to stick my finger in and unlatch the springs. They can be very hard to see, and you might just have to feel around. You will have to move the clutch pedal to various positions to slip the quadrants off. Have patience, this sucks, but it will come off!! (Picture 3, 4, 5) Note in picture 4 how the springs clip onto the bracket. These will need to be unhooked with a screwdriver or something long and pointy. Also note in picture 5 that the spring goes through the center of the arm on the little of the quadrant piece. This is one of the major factors that keep that small quadrant from coming off. When under the car, you may not have good enough access to see all of this, but if you know what you are dealing with, you’ll know how to unhook and slide this assembly out.
Throw both plastic quadrants and springs away, keep the cotter pins. Slip the new quadrant onto both shafts, and put the cotter pins on.
I find that the second hook always seems to work best. DO NOT; I repeat, DO NOT use the third hook, which is the highest position on the UPR quadrant!! It is merely there to get past the Steeda double hook patent. I used it, and it caused the clutch pedal to sit way too high, the cable was too tight, and prematurely wore our clutch out.
Pull the black rubber grommet off the end of the clutch cable that goes into the firewall (after you unbolt the cable from the firewall). On the plastic cable sheath, that is exposed after you remove that black rubber grommet, you will see three tabs. Cut those off with a razor, or file them down with a file. If you don't, you'll see why, it won't slip through the firewall adjuster. Bolt the firewall adjuster into the firewall, slip the cable through the hole in the adjuster, crawl into the car, and slip the end of the cable onto the second hook.
Don't forget to hook the other end of the cable back onto the clutch fork and put the cover back onto the transmission.
http://50stangs.com/techarticles/clutchadjustment/picture1.jpg
http://50stangs.com/techarticles/clutchadjustment/picture2.jpg
http://50stangs.com/techarticles/clutchadjustment/picture3.jpg
http://50stangs.com/techarticles/clutchadjustment/picture4.jpg
http://50stangs.com/techarticles/clutchadjustment/picture5.jpg
