i finally got around to getting a plug to replace the original one.
i have seen these plugs from another manufacturer (fordfuelinjection.com i believe) with the ring terminals already connected on the yellow wire, and with those you just bolt it to the power lug on the alt.
the one i received doesn't have the ring terminal, it's intended to splice in to the existing yellow wire ( w/ white stripe). i assume i can just put a ring terminal on this and bolt it under the power lug on the back of the alt like the other aftermarket plugs i see that have the ring terminal?? i would like to do it this way that way i can totally disconnect the green wire ( which is coming from the black/orange strip wires) at the starter selenoid.
See, there's always a method to someones madness!!!
