  • SN95 4.6L Mustang Tech
Question about C/C plate install
  • Thread starter Thread starter Jinx
  • Start date Start date May 19, 2006
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
May 19, 2006
  • May 19, 2006
Is this necessary even if you are replacing the factory struts with aftermarkets?
(quoted from MM install directions)
Step 1. Before dismantling anything on your car, lay a straight edge across the fenders and measure down to the top of the strut shaft. Record this dimension, you will need it later. (end quote)
Why you need it later:
Step 24. If the car is lowered from stock, position the spacers so that the top of the strut shaft is higher than the dimension recorded in step 1 by the same amount the car is lowered. Example: If the car is lowered 1.25" from stock, position the spacers so that the strut is 1.25" higher than the measurement recorded in step 1.
T
tfalk
1,798
Under my Saleen or FFR Coupe
May 19, 2006
  • May 19, 2006
Regardless of using old or new shocks, you still need to position the top of the strut correctly.
So yes, you do need that measurement.
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
May 19, 2006
  • May 19, 2006
Thanks. I was not sure about the measurement because the struts are different brands and they may be a different overall length, and I was not sure if that measurement comes into play or not?
T
tfalk
1,798
May 19, 2006
  • May 19, 2006
Overall length should be similar. In any event, the critical measurement is how far the top of the strut is from the top of the fender. That will determine how many spacers you need above and below the plate.
BTW, when you install them, make sure you remove the socket from the top of the strut before you close the hood. Ask me how I know...
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
May 19, 2006
  • May 19, 2006
DOH!!!
Good point . Another good tip is to make sure your wiper arms are down against the glass before opening the hood. Ask me how I know..
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
