My brother has been having some trouble with his car. He has a 95 GT that he just did a h/c/i swap on, and it is not running very well. It WILL NOT idle whatsoever, and isn't very drivable at lower rpms. At high rpm-wot it runs beautifully.
The sad part about this is, this is after he took it in to get dyno tuned (http://www.dbperformancetuning.com/).
The tuner told him that 94-95 Mustangs are very finicky about camshafts, and the only way one can change out from the factory camshaft is to have one custom ground. Either that or convert the ECU and harness to a fox computer. He is currently running a TFS stage 1 cam.
If it matters, his h/c/i combo is TFS track heat heads w/ 1.6rr, TFS1 cam, and Cobra intake.
I thought that I had heard of folks running different camshafts with success in 94-95 Mustangs, so I figured I would post here and see what some folks more familiar with these cars think. The tuner was evidently supposed to be knowledgeable, but I figured it wouldn't hurt to double check.
Thanks for any input.
