a50sn95 said:
Since the ightning MAF is for the 42's it should start and run. As far as plug, I don't know, I've not seen a Lightning MAF...
Sorry this is dead wrong. The Lightning MAF is NOT calibrated for any injector - Ford doesn't do it this way. Pro-M and C&L trick the computer and when they do this load calculations - which control timing, are off.
I had one of the quickest '95 Kenne-Bell's on drag radials in the country it ran 11.1/123 (At our home track - National Trails!) in my 3700# vert. I ran 42's in it.
Basically, a good sound combo for a 94-95 KB - and we have tuned a TON of them, is 42# injectors and a 90mm LMAF, with a 255 LPH in-tank fuel pump. 42# injectors are not 'too much' in fact you could use any size up to 60# if you'd want to - that's what I run now. You can always lower the pulsewidth. But if you get an injector too small, you can't do much to increase the flow outside of raising FP.
One thing KB does NOT tell you about using a KB without an FMU is you need to connect the FPR to the boost side of the blower so it sees boost so it can raise FP 1:1 - all FPRs are boost sensitive so that's not an issue. The other thing is, if at all possible the ACT should also see boost - in a 95 it's in the powerpipe. It needs to be moved. If you have the GT-40 lower, there is a threaded hole in the #5 runner to move it to. If not you can either drill and tap the #5 runner or some people have put it into the KB dischage manifold.
Not sure which KB you'll get, but I'd suggest the 2200 with Flowzilla - they make great power. A 75mm TB helps too - on a twin screw, you need all big parts ahead of the blower.
Get the LMAF and injectors here - best deal around - $319
http://www.buyfordmotorsport.com/shop/index.php?show=specials
You'll need a Late model pigtail connector - F68Z12A690-AA and a filter adapter of some sort. We sell the adapters and pigtails if you can't find them anywhere else. You also will need a 4" round filter and a 4" silicone adapter to whatever sized powerpipe you have. You'll also need a chip/tune to get this to work right.
With a Flowzilla you can only use a stock FPR - aftermarket won't fit. And get rid of any underdrive pulleys you might have.
Hope this helps - if you need any more info along the way - email me at
[email protected], I'll be happy to help.
Good Luck!
Don
