Question about lifters
  • Thread starter Thread starter 91lxstang
  • Start date Start date Sep 5, 2004
9
91lxstang
191
Reno, NV
Sep 5, 2004
  • Sep 5, 2004
Stang gods please help me! I'm up to my elbows in a head change, and I need to know what I should do? I've heard that sometimes the lifters can collapse, from the valve spring upgrade is this true? Also if it is, should I get new lifters? And if that is the case, is it bad to use the old cam (stock) and new lifters? Thanks for any info!
04sleeper
2,674
14
89
Dallas, TX
Sep 5, 2004
  • Sep 5, 2004
Your stock lifters should be just fine. If they are still in good working order then you will be ok. Classes like Street Warrior require the use of Factory lifters and they work just fine for them.
If you were to get new lifters then it would be ok to run them with your stock cam. Roller lifters are very forgiving when it comes to changes.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
K
collapsed or stuck "lifter" ?
  • kingcoy
  • Oct 23, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 23, 2025
nickyb
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
