question about mass air sensors
Texstang9682
115
Austin, Texas
Ok so I was planing on getting a mass air meter for my car. I will continue to use the stock 19# injectors. So I was thinking about getting the 90 mm lightning mas air meter and just use my 19# electric module with the 90mm housing. Will that work? I really hope so. I'll just ditch the 42# module. Please dont say I should get a Pro M or C&L. The Lightning MAF is only 80 dollars. And Im the ultimate cheapo. And what is the deal with companys like C&L or Pro-M that offer larger mass air meters but are still calibrated for use with 19# injectors. Are the electronics more responsive on those or what? Im sure im not the only person wondering. Yall guys seem to know your stuff when it comes to the mod motors and I respect your opinions.
Thanks, Clint
the Lightning MAF will not work with your car unless you get a tune. The module is not set for any specific fuel injector, the computer has the fuel injector calibration in the tune.
Stock MAFs are not calibrated, the computer is. Aftermarket MAFs that supposedly are calibrated for larger injectors give false readings to the computer to keep the a/f ratio somewhat safe.
whenever you change a MAF you should get a tune.
well, i was just going to keep the metering module from the stock one. I have cut out the bar in the middle and grinded it down some with the stock unit and it looks like it would flow pretty well. But if stepping up to the 90mm isnt going to help, than i'll just keep the stocker. Thanks, guys!!!
If you change the area of the opening in the MAF, either by swapping your electronics into a bigger housing or altering the stock housing by cutting obstructions out, you will change the electrical response relative to the actual amount of air flowing through it, and it will no longer match the mass air transfer function in the computer. Normally, increasing the airflow while keeping the stock electronics will result in a leaner than normal condition. Modest changes will be accounted for by the adaptive control system, but it will still be leaner than normal at WOT.
Your MAF is probably the single most important sensor in the whole powertrain control system and you would be well advised not to screw around with it unless you really know what you are doing. Most tuners can give you a tune up that will work with a modified meter, or a meter like the lightning meter, especially on the dyno, and as someone else said you would be well advised to get a professional calibration if you modify the meter.
-Matthew
