Drivetrain Question about rear differential clutch
  • Thread starter Thread starter dqureshi06
  • Start date Start date Sep 9, 2024
First Prev 2 of 2
D
dqureshi06
102
21
28
Virginia
Dec 17, 2024
#21
  • Dec 17, 2024
  • #21
limp said:
Its like snow skiing... If you don't crash, your not trying...... Just don't scoop up a butt full of snow on a cold day.....
The car will still feel faster with both wheels actively spinning right?
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,518
2,941
173
Florida
Dec 18, 2024
#22
  • Dec 18, 2024
  • #22
The idea is you have both wheels spinning so you have less tire spin....
Ever seen a " one legger" doing a burnout?
Reactions: dqureshi06
manicmechanic007
5 Year Member
Sep 26, 2017
2,559
726
143
Roy, Utah
Dec 18, 2024
#23
  • Dec 18, 2024
  • #23
My first car was a 69 Camaro with a stout 350 and no posi
Would burn one wheel for half a block
Couldn't afford a 12 bolt posi at the time
Yes, it'll feel faster and be faster if you don't burn one wheel for half a block
The idea is to get moving quick
Having two tires put power to the road is the way to do that
General karthief
Mod Dude
Aug 25, 2016
28,113
10,729
213
polk county florida
Dec 18, 2024
#24
  • Dec 18, 2024
  • #24
Hummmmm, I always thought 2 rear tires driving means you can get sideways farther
2000xp8
SN Certified Technician
Aug 8, 2003
8,067
1,654
194
NJ
Dec 18, 2024
#25
  • Dec 18, 2024
  • #25
Personally i don't think one of these cars are worth owning without the rear operating correctly. Might as well be an old pickup truck.
And as far as not hurting anything running it the way it is, my buddy always complained in the past that if they were run too long non functioning (he did this for a living with foxes) that the pin could somehow get stuck and not want to come out, which may not be the end of the world at a shop, but could be hell in a driveway.
For arguments sake i texted him, the response i got was that if the spider gears got loose from a lack of tension is could be a issue. I know he really used to whine about back in the day, so i'm not sure the level of "issue" the problem is.
As for faster, of course it's going to be faster, you would be doubling the traction.
I also stand by what i said a page earlier (though i must be getting old, i didn't remember writing it).
The second you crack that cover, you should rebuild the entire rear. Do it once and get it over with, done correctly with a set of gears you will never do it again.
Reactions: dqureshi06 and General karthief
D
dqureshi06
102
21
28
Virginia
Dec 18, 2024
#26
  • Dec 18, 2024
  • #26
The rear end is rebuilt at some point it had 3.73 gears, thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,084
224
Massachusetts
Dec 18, 2024
#27
  • Dec 18, 2024
  • #27
You know, the rear clutches on my 2000 were completely smoked. When i pulled the pin out it had heavy wear on the shaft that I haven't seen before on some of the pins i';ve pulled on cars with functional rears. It looked like the center pin was able to twist more freely and was beating up the pin.
But i'm with you. If a vehicle has a specific function, i need it to work. I have no desire to use cruise control on my Fox, but it's functional. If it wasn't, id fix it.
Reactions: General karthief and gkomo
Admin Dude
Jan 4, 1985
43,531
21,699
234
Box behind Walmart
Dec 19, 2024
#28
  • Dec 19, 2024
  • #28
View: https://www.youtube.com/watch?v=fZU22ZPEpOE
First Prev 2 of 2
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
J
  • JRC99
  • Apr 19, 2025
JRC99
J
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
