HOW DO YOU KNOW IF IT IS RUNNING RICH?
WHEN I STAND BEHIND MY CAR IT SMELLS AND MY EYES START GETTING WATER -E-
I JUST INSTALLED A 70 BBK THROTTLE BODY AND THEY SAID THAT IDLE SCREW WAS ALREADY PRESET.
from what i've dealt with on fox 5.O's 14-17* base timing with octane spout plugged in is ideal for a stock to mild setup. should be around 10-12* with it unhooked.
mike
THE ONLY THING THE ENGINE HAS RIGHT NOW IS THE 70MM BBK THROTTLE BODY, BBK SHORTYS, AND AN OFF ROAD H PIPE.i dont know if this applies to your problem or not, but when i had a 94 tbird 4.6 , the mass air sensor itself was dirty and was smoking with the smell of raw fuel from the exhaust. bought a can of electrical contact cleaner and cured it.
since im new to the site a list of your mods would help to know what might be the problem.
mike
i was told that 1987 -1988 mustangs did not have mafMike, I thought you were going to say Octane rod - that's old-timer talk.
Random thoughts to the guy who types in all caps:
Turn caps off.
If you dont have cats, even lean stoichiometry can 'smell' rich. It's part of having no catalyzation occuring.
GTO is right about the TB.
Seeing timing jump about 6-12* once you plug the SPOUT connector back in is about normal.
I'd pull codes first. Something regarding a rich mixture can often be in the form of a soft code.
And cleaning the MAS like Mike mentioned is never a bad idea.
Good luck.
You're correct - from the factory they did not. Many factory SD cars are converted to MAF but I appear to have missed the boat on realizing you had a SD stang. Disregard the MAF mentionings.
Apologies and good luck.
