question on driveline angle
wicked93gs
1,198
229
93
Nashville TN
alright, right now as it sits my DOHC 4.6L engine with T45 tranny in my '66 sits at 4 degrees....I know the reccomended angle is 2-3 degrees...which is what I am trying to achieve...the 4 degrees I currently have is with the stock "floor support" or transmission crossmember still in place...so it looks like I will have to remove it(or at least cut out the top)...not a big deal to me...I am wondering however how much structural support I will lose by cutting it...keep in mind the new transmission mount on the T45 will bolt to a new bolt-in crossmember that will bolt to the frame rails similar to what a fox-body mustang has, so hopefully I will retain some strength that way...I am more concerned because my catalogs list it as a "floor support" I am wondering if without it the floor will weaken...if I had to guess I would say no(not to any real degree), but I just dont know...I am making all the mounts and crossmembers i need myself, so suggestions to increase the strength are welcome, suggestions to buy something I can make myself are...not so welcome
engine is already as low as possible with the oil filter/water outlet assembly just 3/16" above the steering rack, besides I already made the passenger side engine mount bracket with that in mind...though I may re-design the mounts if I find a better way to do it
You can notch the floor support for the added clearence. There was a thread awhile back that showed some good pictures. On T-5 conversions, I notch the floor support and weld a flat plate back up into the section that is notched out. Use a heavy plate, at least 3/16" plate. If you don't feel that is sufficient, and I would probably do this for your application, you can get some wide C channel or fab up something that works, and weld some bracing across the top where the floor support was notched. But that is probably overkill.
Found the thread:
http://forums.stangnet.com/765879-tko600-install.html
There is a picture in that thread of the floor support notched out. Nice clean job too. You can see that one side is left intact. You can cut allthe way accross if you need the clearance. Just weld it up completely.
From my research, (not experience) you want to concentrate more on making sure your rear end is parallel.
in other words, if your engine/trans sits at + 4, then put your rear end at -4. you can get wedges for your leafs to adjust pinion angle back there.
4 degrees doesn't sound bad at all
thanks for the advice guys, I can live with 4 degrees I guess, though slight notching of the crossmember will still be needed just so the top of the tranny doesn't rub while the engine is running...but 1/4" or so should do the trick
