R red93fox New Member Aug 25, 2004 41 0 0 Dec 16, 2004 #1 Dec 16, 2004 #1 well i know how to install it, it's just that in the directions it says to use mineral spirits or an equivalent solvent to clean the cam b efore lubing/installing. can i just wash it down with water and then dry it?
EMW150 Founding Member May 22, 2000 2,020 1 46 Roaring Spring,PA Dec 16, 2004 #2 Dec 16, 2004 #2 I usually just use carb cleaner and dry and put on assembly lube.
R red93fox New Member Aug 25, 2004 41 0 0 Dec 16, 2004 #3 Dec 16, 2004 #3 i dont have any carb cleaner laying around so would water be fine?
EMW150 Founding Member May 22, 2000 2,020 1 46 Roaring Spring,PA Dec 16, 2004 #4 Dec 16, 2004 #4 Should be, just dry it good and oil it up so it doesn't rust.
R red93fox New Member Aug 25, 2004 41 0 0 Dec 16, 2004 #5 Dec 16, 2004 #5 adfsadfsadfsadffadfadfs anyone??
