Questions about A/C Compressor lines
latham83
496
Hey maybe somebody will know this...if anyone has a/c in their 5.0 you know that on the bigger hose that runs along the back and drapes across some of the upper intake, there is a kind of like insulator that protects the hose from heat..and also on the other smaller compressor hose near the pass side their is an insulation on that too...i ripped mine off cause it was like dry rotted and falling off...and i redid my engine..soooo..where can i find new stuff to put on there or something that relates to that???
If you go to a commercial HVAC supply house the stuff is called "armor flex". The stuff you get from them is usually split kinda like convoluted tubing for wiring harnesses and it has an adhesive on the split so when you put it on it will stick together.
