  • 1994 - 1995 Specific Tech
QUESTIONS!!!
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Oct 14, 2007
DDSTANG94
465
FRASER, MICHIGAN
Oct 14, 2007
  • Oct 14, 2007
OK what causes a clutch to chatter only when its hot, if I dive it when its cold it is smooth. After it warms up its noticeable. Also if I'm cruising, for example in 2nd gear, and the rpms are at about 2000 and i let off the throttle on deceleration it will buck, also if I'm cruising and i kinda tap the gas real quick to get the car to jump forward it bucks also. There seems like there is a lot of slop in the drive train, when i shift into second i get a thud and a lot of drive train movement? rear end, drive shaft, u joints, trans or motor mounts?? could it be any of them???
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Oct 15, 2007
  • Oct 15, 2007
T/O bearing. When mine was hot it made a ton of noise!!! When it was cold it was OK. Changed it out...all day job with a 4.6L and L/T's. But it solved my problem.
DDSTANG94
465
FRASER, MICHIGAN
Oct 15, 2007
  • Oct 15, 2007
throw out bearing is new, and im not hearing any noise?
HISSIN50
34
129
Oct 15, 2007
  • Oct 15, 2007
I'd have postulated it was two separate issues. A chattering clutch occurs as you engage or disengage it.
The bucking upon deceleration (dashpot) is likely a tune/sensor issue. Ditto for stabbing the gas - those are transient maneuvers which actually have a fair amount of code to make happen smooth.
If your clutch is chattering, as you let the pedal out, the car can shake (it feels like if you accidentally put it in 3rd gear and try to leave from a light). That should be separate from what you describe unless your clutch is simply slipping, in which case you'd know it and you'd have issues across the board (WOT issues, etc).
Where is the point of engagement (near the top or bottom of the pedal travel)? If it's near the bottom, that can explain the thud while shifting.
I would start with codes - see if your TPS took a dump or something (TPS is huge with transient maneuvers).
Good luck.
DDSTANG94
465
FRASER, MICHIGAN
Oct 15, 2007
  • Oct 15, 2007
Good luck.
thanks for the reply. the clutch enganges right at about the brake pedal...i took the car out and brake touqued it and it atctualy seems better,( the chattering)
HISSIN50
34
129
Oct 15, 2007
  • Oct 15, 2007
If the chatter occurs at the POE (point of engagement), you might have to remove some glaze. In the old days we'd find an empty stretch of road (I mean a closed road course) and light 'em up................... There's always a chance this will make it worse (we were prepared to replace the clutch anyhow).
If the clutch really is chattering, replacing it and resurfacing the flywheel (or replacing it - when they get hot, they glaze and can crack) is probably the answer.
If you haven't, just keep driving it (heat cycling the clutch). The issue will probably get better or worse in short order. It just depends how bad it is.
MHO.
Good luck.
DDSTANG94
465
FRASER, MICHIGAN
Oct 15, 2007
  • Oct 15, 2007
MHO.
Good luck.
thanks hissin. ill see what it does over the next week....by the way the clutch and flywheel are new
HISSIN50
34
129
Oct 15, 2007
  • Oct 15, 2007
FWIW, since you mention the clutch and flywheel are brand new, during the break-in period (clutches and flywheels each have break-ins, respectively) some packages will chatter. If you have an organic disk, this is pretty likely.
Don't get on it for awhile - you cannot undo glazing and hotspotting on a new clutch (I give clutches 500 miles personally. Most folks are easy on them for far fewer miles). Just let those parts bed together and get familiar.
DDSTANG94
465
FRASER, MICHIGAN
Oct 15, 2007
  • Oct 15, 2007
car has about 800+ miles on it for the break in....didnt give it hell till about 450 500 miles..
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
