Quick Injector Question
Black Sun 5.0
1,337
L.I., N.Y.
I'm having a new motor installed after my recent meltdown. I'm moving a lot of my hardward from the old engine to the new one. My mods with be Windsor Jr. heads, Cobra Intake, Steeda #18 cam, 1.7 rr's and will be adding a supercharger with 5-6lbs of boost in the future. Without the supercharger, should I upgrade the injectors now or can I wait? Will I be too fuel starved after adding the cam? Assuming I should upgrade, what should I go to, 30lbs?
You will be fine with your stock injectors for now. When you do get a new set I would go with 42 lb. injectors and matching 80mm Pro-M. This will work fine for your blower combo and give you some room if you want to add more boost later.
