I just bolted on my TFS R lower manifold to my 347. I followed the torque spec in stages (12lbs, 16lbs and 22lbs) My question is, how many times should it take for ALL the bolts to be 22 ft/lbs? I did the 22 ft/lb sequence 3 times and every bolt still needs a little more of a turn. I'm afraid i'm going to tight and i'm gonna fu ck my head threads up or snap the arp bolts. Should I keep going until every bolt is 22 ft/bs or what? Remember, i've gone through the 22 ft/lb sequence 3 times now and it still needs to be done again.
Fwiw I used motor oil on the bolts for a lubricant.
Mike
Mike
