Quick question on torquing lower manifold
  • Thread starter Thread starter Grn92LX
  • Start date Start date Jul 1, 2005
First Prev 2 of 2
9
90Notch
1,046
Westwood, MA & yes it's killing me that I'm no
Jul 2, 2005
#21
  • Jul 2, 2005
  • #21
"The distributer is being a bitch and not wanting to go all the way in. "
Make sure that the oil pump shaft has proper clearance in it! I had same problem many years back where distributor would not seat properly and I never gave thought that the FMS hardened shaft was too tall. Found out the hard way shortly after when shaft snapped in two.
Rick 91GT
Mustang Master
95
99
PA
Jul 2, 2005
#22
  • Jul 2, 2005
  • #22
Mike I set the clearance with a stock dist I had, did you check it with your's? When you put the dist in earlier in the build when you were putting the pan on was it still hard to get in?
Make sure you put some oil or assembly lube on the gear before you install it. I've never run into a clearance issue with the FMS shaft, just the ARP's.
Have a safe weekend, if you need any help give me a shout. Let me know about the oil pump shaft....
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 2, 2005
#23
  • Jul 2, 2005
  • #23
Rick it went in fine, its just yesterday when I tried putting it in it wouldn't go. Hopefully it goes in tomorrow and it doesn't hold me up.
I will throw some arp lube on it.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 3, 2005
#24
  • Jul 3, 2005
  • #24
Rick you have mail.
The pump shaft wasn't in the oil pump hole, thats why it wasn't going in. I used a magnetic tool and got the shaft in place. Right now I have the oil pump primer in and all set to go.
First Prev 2 of 2
Engine Re-torquing intake manifold bolts question
  • 91GTstroked
  • Feb 22, 2025
Fox 5.0 Mustang Tech Mar 1, 2025
Jarhead67
J
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
DadLife0724
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
