Guys, I know there's been countless threads on this subject, but I can't find the answer to a specific question.
My car is using lots of oil still. Like a quart+ in 200 or so miles. The tube from the oil filler to the TB is wet with oil, and there was oil in the upper intake when I put new gaskets on. Car doesn't smoke and runs like a scalded mule in heat on a hot July day with a carrot hanging in front of him drenched in salt.
The catchcans that you guys are running...I've read people's posts that say it really helps their oil consumption. My question is, does it help oil consumption because you dump the oil from the can back into the car, or does it actually cause the car to quit using (or sucking) as much oil? What I mean is, to benefit from the can and have less oil consumption, I assume I'll have to dump it back into the engine, correct?
Thanks for your help!
DW
DW
Tell me more about what I had said and I will try to clear that up.
