R reefshow New Member Sep 5, 2007 34 0 0 eastern pa Oct 8, 2007 #1 Oct 8, 2007 #1 WHICH WIRE IS THE SIGNAL WIRE ON A 89 GT FRO THE MAF? THANKS
68keyblr 20+ Year Stangneter Mar 17, 2003 946 20 49 Arizona Oct 8, 2007 #2 Oct 8, 2007 #2 C is the negative signal, D is the positive signal iirc
R reefshow New Member Sep 5, 2007 34 0 0 eastern pa Oct 8, 2007 #3 Oct 8, 2007 #3 I NEED THE MAF SENSOR OUTPUT THANKS!
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Oct 8, 2007 #4 Oct 8, 2007 #4 Your DMM can help. The output sig should show about 1 volt at idle and go up as air flow goes up.
R reefshow New Member Sep 5, 2007 34 0 0 eastern pa Oct 8, 2007 #5 Oct 8, 2007 #5 anyone know the color of this wire? right off the plug to the mag there is a blue,sorta yellow red and black and maybe a green dont remember .....i measured them all with a volt meter and the only one that moves is the red one ...
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Oct 8, 2007 #6 Oct 8, 2007 #6 There might be something wrong with your DMM or method. If you blow through your meter, this should make the signal change. Here's a diagram (thanks to site host S&2B's and author TMoss ) Good luck. Attachments 88-91_5.0_EEC_Wiring_Diagram.gif 168.5 KB · Views: 169
