QUICK SIGNAL WIRE COLOR ON MAF!
Your DMM can help. The output sig should show about 1 volt at idle and go up as air flow goes up.
anyone know the color of this wire? right off the plug to the mag there is a blue,sorta yellow red and black and maybe a green dont remember .....i measured them all with a volt meter and the only one that moves is the red one ...
There might be something wrong with your DMM or method.
If you blow through your meter, this should make the signal change.
Here's a diagram (thanks to site host S&2B's and author TMoss )
Good luck.
