  • 1994 - 1995 Specific Tech
Radiator Help
  • Thread starter Thread starter DFG 5OH
  • Start date Start date Aug 12, 2005
DFG 5OH
1,341
Louisville, KY
Aug 12, 2005
  • Aug 12, 2005
Well i made a thread about my car getting too hot. So i'm thinking about getting an alumn. radiator. My radiator leaks some...and prolly doesnt cool as good as it used to. my question is, would an alumanum radator out of a 94 T-Bird fit my car? I read that they were a direct swap, and a good/cheap way to get a better radiator. Also, i found a radiator out of a 96 cobra. Would this fit? And i also found a what looks to be Alumn. radiator outta a 96 GT. Which of these would be the best fit/deal? I could prolly get all of them got under $100.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Aug 12, 2005
  • Aug 12, 2005
Dont know....but wouldnt mess around with old junk...Get a Fluidyne and be done with it...esp if youre going to continue to mod the car.
RC
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 12, 2005
  • Aug 12, 2005
Just in case you didn't know, your stock radiator is aluminum too......Just wanted to clarify in case you thought different.
But seriously, buy a good aftermarket radiator and be done with it.
Scott
DFG 5OH
1,341
Louisville, KY
Aug 13, 2005
  • Aug 13, 2005
i dont have the funds right now to get a new rad. i didnt know the stock was alumn. i'm gonna check a local junkyard and see what i can come up with, if a t-bird's rad. is no bigger then i'll stick with the one i got.
HISSIN50
34
129
Aug 13, 2005
  • Aug 13, 2005
Both cars came with 1" thick radiators IIRC. I just looked up specs from one source (definately take this for what it is worth - I dont trust many such sources). It said that the bird rad (for a mod motor in the year you listed) is a couple inches less wide, a few inches taller and might have different hose bung sizes.
Just a heads up. FWIW, one can get rad's online (oem replacements) for around 100-120 bucks.
Good luck.
DFG 5OH
1,341
Louisville, KY
Aug 13, 2005
  • Aug 13, 2005
so a t-bird rad wouldnt be any better ****. maybe i just needa clean mine or something. How do i flush it out REAL good?
HISSIN50
34
129
Aug 13, 2005
  • Aug 13, 2005
Some guys use products like CLR to remove scale inside the radiator.
But if yours leaks, that is not good and it might leak even more after doing that (you will unclog all the pin holes leaks).
You are also losing cooling ability by not having the system quite at full pressure (each PSI increases the effective boiling point by 3*F).
For the birdie radiator, like I said the info was just to be taken for what it's worth. A quick eyeballling of one is worth it, but they had a small front end just like stangs.
I have come across one guy who said he used a HD fox 3 core radiator in an SN. But that radiator now costs about what an alum universal radiator does and would likely require just as much fabrication to fit.
I am trying to think of budget ideas and not doing so hot. You can call a rad shop or 10 and see what they say. I kinda doubt they can do much with our stock radiators since they have plastic tanks. Maybe they have or can whip something up that would fit and not cost too much. It might be worth taking 10 mins to call.
A lot of online rad places have free shipping, lifetime warranty and cheap prices.
Good luck.
DFG 5OH
1,341
Louisville, KY
Aug 13, 2005
  • Aug 13, 2005
i called a local junkyard, they've got one. I dunno if i should go look or not. I'm gonna get a 180* thermo from autozone and see if that helps.
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
I
2000 GT Mustang - Transmission Cooler to Radiator o-rings
  • Iwarrior
  • Oct 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 4, 2025
Iwarrior
I
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
