So as stated with the crossover thread, my local shop was able to repair the crossover pipe and it seems to be functioning properly, the only problem is when I pulled out of the shop the radiator light came on. I went back and the tech that worked on it covered his ass nicely and said "I just messed around with this pipe and the only thing I can tell you is the harness that comes out of top of the coolant reservoir on the drivers side can go bad sometimes" and to his knowledge the only way to fix it is to replace the entire reservoir.
The light wasn't any issue before and would come on every two weeks when my coolant would drop a few inches in the reservoir(again it was due to the poorly diagnosed leak that two radiator shops couldn't find...) I just want the light functioning again so I know when I am low on coolant - which hopefully isn't too frequent!
Let me know what you guys think, I reset the computer by disconnecting the battery he and the light is off now, but I am sure with my luck they already did that, I would assume, and it will come back on...I'll be honest their was some coolant that spilled out of the reservoir when it first overheated before the shop - could this fry that harness?
Advice is much appreciated~ Thanks!
