  • 1994 - 1995 Specific Tech
Radiator?
  • Thread starter Thread starter gt96stanggt
  • Start date Start date Dec 19, 2005
G
gt96stanggt
106
Tempe, AZ
Dec 19, 2005
  • Dec 19, 2005
whenever i really got on my car and push it, all my coolant goes into the overflow and then the overflow cap pops off and lets the coolant out and the car over heats! so now i carry water with me every day! i have no idea why it does this? any help is greatly appreciated! it sucks because this is causing me not to be able to take it out to the track! :SNSign:
bypassed heatercore, stock radiator, stock overflow. amnit:
bill302
2,131
alabama,gadsden
Dec 19, 2005
  • Dec 19, 2005
Go Get Your Cooling System Pressure Checked. That May Answer All Your Questions. You Can Get It Done At Any Radiator Shop.
bill302
2,131
alabama,gadsden
Dec 19, 2005
  • Dec 19, 2005
Oh Ya I Would Replace The Radiator Cap First And See If Thats It Before A Pressure Check.
G
gt96stanggt
106
Tempe, AZ
Dec 19, 2005
  • Dec 19, 2005
Will do! Thanks! do you know how much it would be to get it pressure checked?
bill302
2,131
alabama,gadsden
Dec 19, 2005
  • Dec 19, 2005
Don't Know, I Do It Myself You Can Buy A Pressure Tester And Do It Yourself I Believe They Come With Instructions Call Your Local Parts Dealer And Ask Then Call The Radiator Shop Get Prices And Decide The Better Route. Let Me Know Results
G
gt96stanggt
106
Tempe, AZ
Dec 19, 2005
  • Dec 19, 2005
will do asap.. thanks!
S/CBlack95GT
2,018
Tampa Palms, FL
Dec 19, 2005
  • Dec 19, 2005
Sounds like a head gasket problem to me.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Dec 19, 2005
  • Dec 19, 2005
Head gaskets or your fan isn't turning on.
RFMustangGT
294
Knoxville,TN
Dec 20, 2005
  • Dec 20, 2005
I just had the exact smae problem tonight. I'm guessing the t-stat has gone bad. I just did a head swap and it was overheating at first but I thought it had an air bubble in the system. well, it quit doing it and it was fine till I just drove home. top rad hose was really flexing, overflow tank was full with antifreeze all over the place. I'll let ya know when I change it out tomorrow if the problem continues.
95COBRA241
339
Delray Beach, FL
Dec 20, 2005
#10
  • Dec 20, 2005
  • #10
It sounds like one of two things. Either the t-stat is staying closed not allowing the coolant to flow thru the system or the radiator cap is not allowing the system to properly pressurize.
bill302
2,131
alabama,gadsden
Dec 20, 2005
#11
  • Dec 20, 2005
  • #11
thats why i would do a pressure check, if the cap replacement don't work. a pressure check will test the head gasket for leaks and test for possible cracks in block or head allowing exhaust into cooling system and blowing fluid into holding tank. after test results you can troubleshoot according to results. also check for oil in water or water in oil, if water is in oil you will have a white foam under your oil cap, if oil is in water it will float on top of fluid when fluid is cold.
RFMustangGT
294
Knoxville,TN
Dec 21, 2005
#12
  • Dec 21, 2005
  • #12
well, I checked out mine today and apartently my buddy who was helping put the damn t-stat in backwards. but I was thinking about it today aboutyour problem. if it's not a head gasket, it could be low coolant and it is now vapor locked where there is no water in the intake preventing t-stat to open. dunno if that could be it or not but something to think on.
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
