Re-torque guidlines on heads
Nicoleb3x3
274
southern NH
I recently rebuilt my engine and I'm going back to re-torque my head studs.
I've probably run close to 400-500 miles without going back to re-torque yet; but I've driven the car very mildly (under 3 grand) except for a few dyno pulls.
Needs some guidelines (I want to be super cautions that I do don't mess this up because I really don't want blow a head gasket later on)
-does it matter that I've gone 400-500 miles already? shouldn't right?
-I assume I re-torque in sequence and I shouldn't back off anything at all but simply be checking the torque rating is still 85ft lbs.
-does it matter that the lower intake is installed? how does that affect torque ratings with the added pressure of the lower? I certainly hope this doesn't matter.
-Has anyone used ARP 7/16 studs, do the bottom need to be higher torque? because the instructions said 85 ft lbs with moly, it didn't say to do the lower different than the upper row. I think the ARP studs have different tension to make up for the wedge factor?
---->Now; if I have all of them at 85 ft lbs and someone says I should be running higher torque on the bottom row even with these ARP studs...what does that mean for re-torqueing? because adding 5 ft lbs now won't be evenly distributed because I'm adding +0 to the top and +5 to the bottom that woudn't be an even increment accross the sequence? Course I'm hoping both rows can be 85 ft lbs and I should not worry about this!
-If I'm going with a super charger next year, should I retorqe to a higher rating? I'm expecting to see 380 hp to the wheels. Should I just go with the 85 ft lbs with moly that the ARP instructions say? I guess I feel that If I increase it now to over 85 ft lbs then I would have to retoque again later on because of the increased number would need to be checked again....I don't want to go through that if it's not nessasary
Sorry I have so many stupid questions, but I will super pissed If I screw this up. I've good luck so far with this build I want to keep it that way!
You honestly could get away with never retorquing them. The factory didn't do it. Mine have a couple years' worth of usage and were never touched since they were initially installed. Mine were just done by TFS's instructions (85 on the uppers, 75 I think on the lowers). If you haven't had any issues yet related to the headgaskets, you're not going to as a result of the torque specifications you used.
also; fyi the factory didn't re-torque because they use torque to yield bolts...they're designed to use onen time only
technically you're supposed to retorque bolts or studs that are not torque to yield...however...I think about distrubing the coolant passage threw hole bolts that have thread sealer.....I used regular thread sealer and not rtv..I don't think it was a hardening compound..but.....I don't want to make problems for myself either
