really weird ignition control module the devils work?
i just got done converting my 86 5.0 to mass air after three years of dic***g around just now trying to start it and i have a hot fusible link...checked every single wire and if it was even bent and MAY have caused a problem i cut soldered and heat shrunk every connection...anyway with the key on if i move the distributor around a little the fule pump primes and it clicks and junk...i have upgraded to the cobra gt40 intakes and the thermostat housing is bigger than stock so the module rubs and on it..initially a lot until i got frustrated and yanked it forward...quite stupid so my question is is there possibly something cracked in the module causing this problem? or would it have to be the wiring because no matter how much i play with the wiring attached to the module it doesnt do anything it's only when i physically move the distributor....anybody know how to quickly test the module to make sure it is in face the problem? also if i need a new one would it be beneficial to upgrade the module to an accell or no difference since it's a stock distributor? thanks for your brilliant genius
"save a tree....eat a beaver"
Yanking on the module isnt a good idea, as you saw. For the original issue (dizzy hitting the t-stat housing), you can pull the dizzy and restab it, having moved the mainshaft (aka rotor) accordingly, so things are still as they were (but just shifted). This will get your TFI in the middle of it's range of motion so you are not butting it into anything.
A parts store can test your TFI module. That might be an option for you. Dont get too carried away with heat sink grease when you reinstall the module.
I personally wouldnt upgrade a module for the sake of doing so - there's nothing performance oriented about it. It's just a messenger of sorts (as opposed to the coil, which takes the message and creates a hot spark).
If you haven't, pull codes again. Look for TFI or IDM codes.
Good luck.
