  • SN95 4.6L Mustang Tech
Rear bumper letter install
  • Thread starter Thread starter RedPony
  • Start date Start date Jan 3, 2004
R
RedPony
25
Northwest florida
Jan 3, 2004
  • Jan 3, 2004
i need the link for the how to article, to install my vinyl lettersanyone have it? thanks in advance.
9
98stang4.6
jersey
Jan 3, 2004
  • Jan 3, 2004
this is very easy to do ..... use rubbing alcohol and clean the desired area. make sure its clean and dry then apply the vinyl letters
Benny
414
Katy, Texas
Jan 3, 2004
  • Jan 3, 2004
Clean the surface as suggested above.
Then mix a little soap with water in a spray bottle and wet the area so you can move the letters in postion. Once you have them located lightly squeeze the water out. I used my drivers license!
UA2k1GT
Boned
2,634
Bham/HSV, AL
Jan 3, 2004
  • Jan 3, 2004
01GT eibach
1,075
Pittsburgh, PA
Jan 3, 2004
  • Jan 3, 2004
What I did was have a little cup of soapy water. Remove the letter's backing and fully dunk the letter in the water. Then it will slide around to exactly where you want it. Once in place, squeeze any air out and let dry overnight. This is truly the world's easiest mod ... even easier than replacing the air filter with a K&N. Five minutes tops. Just make sure you have a nice clean bumper to put it on.
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
2003 Mustang GT - Rear Tire Size Question
  • Cassiebaebae
  • Jun 29, 2026
  • 2 3 4
2K
squeak93
H
Electrical 2003 GT convertible battery drain
  • Huggybear56
  • May 31, 2026
SN95 4.6L Mustang Tech May 31, 2026
Bronco2fan
M
Revisit: Convertible 89 vs 90 seatbelts
  • Majbrn
  • Jul 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Majbrn
M
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
