Rear bumper letter install
Clean the surface as suggested above.
Then mix a little soap with water in a spray bottle and wet the area so you can move the letters in postion. Once you have them located lightly squeeze the water out. I used my drivers license!
What I did was have a little cup of soapy water. Remove the letter's backing and fully dunk the letter in the water. Then it will slide around to exactly where you want it. Once in place, squeeze any air out and let dry overnight. This is truly the world's easiest mod ... even easier than replacing the air filter with a K&N. Five minutes tops. Just make sure you have a nice clean bumper to put it on.
:nice:
