Rear Coil-overs, are they worth it?
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Ok well I have a tubular k-member and front coil-over setup and was considering putting in rear coil-overs here in the near future but wasn't sure if it would really be worth the money.
This question is addressed to those who have rear-coil overs or really know their suspension stuff.
Right now I have tokico lowering springs in the back with tokico blue shocks. If i decide to upgrade to coil-overs ill be spending roughly around 400$ because not only will i have to buy the rear coil over kit but a new set of shocks in addition because the tokico blues are not compatible with any coil over kit.
My question is: Is it really worth it to upgrade to rear coil-overs in terms of performance/handling/ride quality? Im satisfied with how it looks/sits right now so i wouldn't be doing this for the look but strictly for the performance aspect.
Thanks in advance!
Give me a shout when your in Houston sometime. Let's meet up, I want to check out the ride again.
Yea man for sure, I get off work in about 2 weeks and will have a month off to do whatever. I got a couple projects lined up already including the Steeda 13" rear rotor package; and am planning on hitting up HRP at-least once, as well as the local car show scene of course and whatever else is going on, they have autocross events at the dog track near my house so i was planning on that as well...anyway i still got your number so ill give you a call when i get back. My last month off was so hectic with xmas and hunting season and all so im planning on devoting most of this next month to car stuff!
Well I called Maximum Motorsports when I was working through the same dilemma. They told me they didn't recommend them for a daily-driven street car, because they would be noisy and stiff. However, seeing as I took their advice, I can't really give you any first-hand impressions or anything.
I have front & rear MM coilovers. Both front & rear are excellent quality setups, but the rears are pretty noisy. I personally would rather go back to standard springs with adjustable LCA's, because they were easier to adjust the ride height & less noisy, but now I have no spring perches on my LCA's. They are pretty stiff, but not any stiffer than regular springs, that all goes with what spring rate you run, & what ride height you set the car at. The lower you go, the stiffer the car will be because it has less travel.
I have MM coilovers as well. Can't beat the quality on them. I run about a 1.8hz spring front and rear. For those that don't know the spring hertz is the frequency the springs vibrate at which also the spring rate in other terms. They say a 2.0 hz spring is pretty much ideal spring frequency for autocross and road racing. Mine is Set like I said at 1.8 hz, or 300 lbs/in. In the front and 225 ibs/in. In the rear on 9.5 in. Tall springs. A good soft street spring is around a 1.5 hz spring which is about 250 lbs/in. Front and 175-200 lbs/in. Rear.
