Rear coilover kit
Ive never been a big fan of their shocks. I put together kits in my shop same price or cheaper with better parts. If your interested let me know...
What is the complete set up?
Rick
I have hotchkiss upper and lowers, full length sub frames w/ cross braces and torque box adapters, eibach sport line springs and oe shocks and struts, poly axle pivot bushings, and other misc poly bushings for front
So what do you guys think?
I think you would be wasting a lot of money. Likely you will have a mismatch in suspension parts. You can't just slap new shocks on the rear with sportline front springs (probably with an unknown spring rate) and coil overs.
Front and rear suspensions should be setup to work with each other, or you risk serious handling and safety issues.
Buy yourself a good set of adjustable shocks for the whole car. (my preference is koni).
Then when the time comes you could use the MM coil over kit on them.
Not only are your stock shocks and struts probably worn out, but they probably suck with sportline springs even worse.
