Rear Control Arm opinions
I'm not trying to beat a dead horse, believe me I've searched and read about every thread on this subject, a little overwhelming actually. I think I've narrowed it down to 3 possible options/scenarios, and if I could get your vote with the parameters I have that would be cool. Or if you have other combos that you think are better in this range I'm open. Thanks.
Daily Driver
Budget $200-$300
Current suspension - FMS C Springs, KYB's, Steeda CC plates, new FMS A-arms, new end links, poly sway bar bushings, poly rack bushings. Have new Prothane isolators but will wait as I don't want it to be raised any (have trashed stocks in there now)
Future wants: Bilsteins with possibly H&R's or Eibach Sportlines.
Option 1
http://www.uprproducts.com/shopping/shopexd.asp?id=225
Options 2
http://www.steeda.com/products/steel_upper_lower_control_arm_combos.php
Option 3
I've read an adjustable lower from Granatelli is pretty good (kind of a different route), then maybe use a cheaper upper like the Ford Racing for 70 bucks or so (still better than stock I assume). Or like this example should I spend the majority on the lower (MM, Steeda alluminum), and get cheaper upper for now and match it with lower later?
Check out the Maximum Motorsports site.
I would DEFINITELY go with their lowers (andjustable or non is up to you - depending on your wants/needs). Then just upgrade the bushings in your uppers. Ideally (if I had the means), I would upgrade the bushings in the uppers (to the firmer rubber ones like MM suggests) and I would box the upper control arms.
DONE!
