Drivetrain Rear End Comparison
GoldenEagle91
240
Hi guys,
I've got a 79 Ghia that came stock with a 7.5" rear end in it and I am a bit concerned that once I put my rebuilt engine into it that I may run into some problems in terms of its capabilities. I have been told by numerous people including Chevy guys that the only way to go when it comes to rear ends is with a Ford 9" although I don't have the money at the moment to swap in a Ford 9" from a company like Moser or the like so I am trying to weigh out my options so that I don't end up blowing a rear end apart. Is there anyone who has any experience with beefing up the 7.5" or are more people just sticking with beefing up the 8.8"? I was looking at gears and maybe a diff for the 7.5" but I wasn't sure so I wanted to get some of your guys input. Looking forward to hearing back.
Thanks,
Andrew
I have had two fox body cars with 7.5" rear ends. One was a manual and a 5.0. I think it survived because my tires broke loose before anything else broke. I added Ford's limited slip differential and had good luck back then. Now I would start with a factory posi 8.8", maybe one with discs. IMHO, the 9" is nice to have for setting and changing gear with - you do the hard part on the workbench. But unless you are running slicks and shock the drive train with a tranny brake or power shifts, you do not need the extra strength and cost of a custom 9".
Who is running really fast and what was your parts experience?
The engine setup is as follows: 9.0:1 pistons, 58 cc combustion chamber aluminum heads, B303 cam, 650 Cfm carb, 1 5/8 Long Tubes, Comp cams short travel race lifters, aluminum full roller rockers. I had read an article in Car Craft where they did a head comparison and with a very similar setup to what I have they kicked out 350 with my heads. I've got some different parts that are a bit higher end than the ones they used so I'm counting on being around 375 hp and tq. Would a 7.5" be able to withstand that? If I don't have to change anything then I don't want to. I will plan on going to 3.73 gears in the future though.
The 7.5 will live as long as you don't have a lot of traction; with traction, it's not going to be pretty for very long. Changing the limited slip will not strengthen the rear axle assembly. An 8.8 swap is the easiest and cheapest way for you. Sorry....
Street tires? You should be fine. Drag radials or sticky tires, you may destroy your ring and pinion at some point.
8.8 is very easy to install, plenty of aftermarket and cheaper than 9"
I have yet to see anyone yank a fox 8.8 in favor of a 9" unless they were a serious drag racer with a track dedicated car.
Just get an 8.8 from an earlier year fox and you will be fine. I am actually running an 8.8 in my race car. Granted, I have done some serious work to it but, none the less, I have faith in a well built 8.8
To really beef up the 8.8 the main thing to change is the axles and differential right? I have a feeling that 31 spline axles and such are better but I'm not positive. Correct me if im wrong
For a solid street/mild strip 8.8 rearend throw some 31sp axles,diff,some gears,end cover girdle and if you want a little extra safety weld the axle tubes. You'll be good to go
Reactions: 85rkyboby
I second that the 8.8 is plenty strong unless you have a ton more than a bolt on 302.
guys have been 6's on an 8.8...plenty of reasons to go to a 9" over an 8.8 but strength isnt really one of them.
only thing id change on my rear over a streetable rear is the diff. id still run the bolt on bearing ends (9" style) still run the custom made axles welded tubes and the screw in wheel studs.
If I recall right, there were years that used both rear ends, depending on if it had a 6 cyl, 4 cyl or GT. I see the catalogs list the control arms as the same for all Fox body Mustangs. I would think it would be a bolt it, unless there is a brake hose fitting issue.
