Engine Rear main seal keep leaking, second attempt
Swhitney
184
10
28
Oregon City
I know this has been widely talked about, but I am really struggling to fix the glitch.
I have a 1992 mustang with a 347 stroker. I had recently replaced the rear main seal when the engine was out when I was doing engine bay cleanup. The problem is she continues to slowly drip oil. I then pulled the tranny and install the felpro seal savor with a new seal, and yet again she continues to leak. I used blue loctite on the flywheel bolts, and am running the stock PCV valve with vented valve covers. What else should I do to stop this silly leak?
I'm the same with a stock 5L. Brand new seal still drips. I read someone in a forum once say with these cars even Ford considers a slight drip within the range of 'normal'
I also read you're supposed to use thread sealer (not thread locker) on the flywheel bolts.
I read where the seal saver needs to be installed with red loctite or it will leak between it and the crank.....
Yeah I'm hearing that same thing now. I will most likely pull the seal savor and install a new one with green loctite.
There needs to be a full prof way for these things not to leak. When I installed the first one there was no oil pan getting the way so I know that I didn't damage it. Even the 2nd one seems very tight on the seal savor. I assume it could be leaking from around the seal savor or coming out of the fly wheel bolts?
I did the redi sleeve with locktite (blue), but used black RTV on the flywheel botls. Have not put many miles on it, but so far so good.
I just purchased a sleeve and tool ( man what a gimmick) and it says to put non hardening sealer on the sleeve before installing it... So, not sure to use loktite or non hardening sealer.....
Loctite 518 for transmissions and rear axles
Loctite 515 would probably be more appropriate for the sleeve here. However in reading up on these sealers not sure it's the appropriate application as they do harden up.
I bought some Loctite 290 to smear on the inside of the seal savor. The rear main I plan on using a small amount of RTV silicone on the outside, and RTV on the flywheel bolts.
Are you saying the 515 might be the wrong stuff?
Both 518 and 515. I've trying to research the applications.
518 is great for rear ends and transmissions. It works very well against oils. 515 is the same but doesn't work well with aluminum. Both harden however in the absence of oxygen, which is why i am questioning if this is the right application for it
I have a tube of 518 on my shelf. I probably would have just used it.
EDIT: everything i'm reading seems to suggest 518 is ok. 518 has a higher temp rating than 515 but 515 sets faster. Both are rated to fill a gap up to 0.01" which shouldn't be an issue for a sleeve
