  • 1994 - 1995 Specific Tech
rear seal
  • Thread starter Thread starter willbrooks2
  • Start date Start date Jan 5, 2006
W
willbrooks2
11
  • Jan 5, 2006
i am having my tranny rebuilt would now be a good time to replace the rear seal?
H
hiattwl
145
Cullowhee, and Andrews NC
Jan 5, 2006
  • Jan 5, 2006
Probably so since it's easy to access when the tranny is removed.
Swarzkopf
973
Pittsburgh
Jan 5, 2006
  • Jan 5, 2006
Does it leak now?
HISSIN50
34
129
Jan 5, 2006
  • Jan 5, 2006
I am with the above-guys. Before just doing it, how long has the seal been in there and does it leak now (like Shawn asked)? If it aint leaking and the seal's lips are not vulcanized, I almost hate to recommend opening that can of worms.....
Good luck.
CManT1914
3,172
Killeen, Texas
Jan 5, 2006
  • Jan 5, 2006
I seem to remember a saying........
"if it ain't broke, don't fix it!"
Swarzkopf
973
Pittsburgh
Jan 5, 2006
  • Jan 5, 2006
Exactly! If it's not leaking....do NOT replace it! I've done mine TWICE now because it was very minorly leaking the first time. It leaked worse after I replaced it the first time, and still drips now just as bad as it did before. It is NOT easy to do on my AODE car.
W
willbrooks2
11
  • Jan 5, 2006
The seal is leaking . Everytime i move the car there is a puddle of oil.
BDAWK2002
139
Old Bridge N.J.
Jan 5, 2006
  • Jan 5, 2006
That makes it easy.......If its leaking change it.Some guys on here might have some tips for you when putting in the new one about using some RTV on it.Its not easy getting the new one it without leaking.......
HISSIN50
34
129
Jan 5, 2006
  • Jan 5, 2006
I would also caution that a leak from a RMS can be from a clogged PCV system - the crankcase pressurizes and takes the next least path of resistance, which is often the RMS.
Also, a leak at the back of the motor (valve covers, etc) can leak and drip off the back of the motor, right about where a RMS leak would appear to drip from.
Good luck.
yellowstang1994
338
#10
  • Jan 5, 2006
  • #10
I'm on my 2nd seal... followed some tips for installing on here and followed the instructions on the package and it leaks about as good as it did before, heh. Let me tell you what though. The first time I tried to get that damn seal off was a nightmare, it is the biggest PITA ever. It set me back like an hour and some just trying to get it out by prying. The second time I got smart... I took 2 woodscrews and screwed them in the seal a little bit. took the back of a hammer and pulled that sucker right out. Took like 2 minutes and I didn't risk gouging anything around the crackshaft like you would pulling.
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
K
WTB Looking for Door seal channels for 88 T-top
  • Kifferman199250
  • Jul 26, 2026
  • Want to Buy
Want to Buy Jul 26, 2026
F
Leak from tail shaft after 2 new seals
  • Fox123
  • Aug 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 9, 2026
JD1964
Need help 94 GT convertible top leaking
  • Scott94gtvert
  • Aug 9, 2025
1994 - 1995 Specific Tech Aug 9, 2025
General karthief
Engine Oil leaking
  • greenflash79
  • Apr 1, 2026
  • 2007 - 2014 Shelby GT500 Tech
2007 - 2014 Shelby GT500 Tech Apr 6, 2026
greenflash79
